Building Computer - Seek Input
sirsosay
I'm completely new to building computers but I've been looking over the forums and I think I've put together a decent build and was going to ask for your advice.
- Intel Core 2 Duo E6400 Conroe 2.13GHz 2M sharing L2 Cache LGA 775 Processor
- ASUS P5B Deluxe Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard
- GeForce 7600 gt 256mb PCI
- Antec p180 (CASE)
- Antec True Power Trio TP3-650 ATX12V 650W Power Supply
- Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1000
I'm just looking for the best build for $1000 that is upgradeable in the future. Does this look like a good choice?
It looks nice. The only problem you might run into is that the board might not like the higher voltage of the Ballistix when you first try and boot. Other than that, you have a great setup.
Looks like a good build, but I'm wondering why you got such high performance memory when you have a lower end CPU and GPU. :confused:
yeah id drop the ram down to some cheap DDR 800 from giel and get a better graphics card, even drop the cpu down to the 6300 if your gonna be overclocking, a 8800 gts would be awsome if you could drop some prices to afford it.
Drop the power supply down to an 550Watt. I'm the trio 550Watt powering:
C2D E6600
Asus P5N32- SLI Premium
OCZ DDR2 800 2Gb Dual Channel
36.7 Gb WD Raptor 10,000 k
160Gb Seagate Barracuda 7200 k
BFG Geforce 8800 GTS
Yep, looks pretty good.
You could go for an E6300, some cheaper RAM, and a way better GPU.
