Building a UBERBUDGET gaming comp
earthscore
K this is going to be uber-budgeted...... currently this is what i have that i can use on my new cpu: Nice internet keyboard, ball mouse(i hate optical),and a TTXmonitor..... here is the shithole im on now:
im about to go into tons of detail about my comp, feel free to not read.
mobo:Motherboard Properties
Motherboard ID 06/19/2000-VT694Z-CUV4X
Motherboard Name Asus CUV4X
Front Side Bus Properties
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 133 MHz
Effective Clock 133 MHz
Bandwidth 1066 MB/s
Motherboard Physical Info
CPU Sockets/Slots 1
Expansion Slots 1 ISA, 5 PCI, 1 AGP Pro, 1 AMR
RAM Slots 3 DIMM
Integrated Devices Audio
Form Factor ATX
Motherboard Size 210 mm x 300 mm
Motherboard Chipset ApolloPro133A
Motherboard Manufacturer
Company Name ASUSTeK Computer Inc.
Product Information http://www.asus.com/products/mb/mbindex.htm
BIOS Download http://www.asus.com/support/download/download.aspx
Chipset:Chipset Properties
Motherboard Chipset VIA VT8604/5/6 ProSavage PL133/PM133/PN133
CAS Latency 3T
RAS To CAS Delay 3T
RAS Precharge 3T
Integrated Graphics Controller
Graphics Controller Type S3 ProSavage
Graphics Controller Status Disabled
Memory Slots
DRAM Slot #1 128 MB (PC100 SDRAM)
AGP Properties
AGP Version 2.00
AGP Status Disabled
AGP Aperture Size 64 MB
Supported AGP Speeds 1x, 2x, 4x
Fast-Write Not Supported
Side Band Addressing Supported, Disabled
Chipset Manufacturer
Company Name VIA Technologies, Inc.
Product Information http://www.via.com.tw/en/apollo/chipsetindex.jsp
Driver Download http://www.viaarena.com/?PageID=2
Problems & Suggestions
Problem AGP is disabled. This may cause performance penalty.
Problem AGP aperture size is more than half of the system memory size. This may cause performance penalty.
CPU CPU Properties
CPU Type Intel Pentium IIIE, 733 MHz (5.5 x 133)
CPU Alias Coppermine, CuMine, A80526
CPU Stepping cB0
Original Clock 733 MHz
L1 Code Cache 16 KB
L1 Data Cache 16 KB
L2 Cache 256 KB (On-Die, ATC, Full-Speed)
CPU Physical Info
Package Type 370 Pin FC-PGA
Package Size 4.95 cm x 4.95 cm
Transistors 28.1 million
Process Technology 6M, 0.18 um, CMOS
Die Size 104 mm2
Core Voltage 1.60 / 1.65 V
I/O Voltage 3.3 V
Typical Power 11 - 25 W (depending on clock speed)
Maximum Power 16.0 - 37.5 W (depending on clock speed)
CPU Manufacturer
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization
CPU #1 15 %
Physical Memory
Total 127 MB
Used 109 MB
Free 17 MB
Utilization 86 %
Swap Space
Total 1920 MB
Used 128 MB
Free 1792 MB
Utilization 7 %
Virtual Memory
Total 2047 MB
Used 237 MB
Free 1810 MB
Utilization 12 %
Suggestion Install more system memory to improve applications performance.
Bios:
BIOS Properties
BIOS Type Award Medallion
Award BIOS Type Award Modular BIOS v6.0
Award BIOS Message ASUS CUV4X ACPI BIOS Revision 1005
System BIOS Date 06/19/00
Video BIOS Date 12/10/99
BIOS Manufacturer
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
Suggestion System BIOS is more than 2 years old. Update it if necessary.
Suggestion Video BIOS is more than 2 years old. Update it if necessary.
SPD Memory Module Properties
Serial Number None
Module Size 128 MB (1 rows, 4 banks)
Module Type Unbuffered
Memory Type SDRAM
Memory Speed PC100 (100 MHz)
Module Width 64 bit
Module Voltage LVTTL
Error Detection Method None
Refresh Rate Normal (15.625 us)
Highest CAS Latency 3.0 (7.5 ns @ 133 MHz)
2nd Highest CAS Latency 2.0 (10.0 ns @ 100 MHz)
Memory Module Features
Early RAS# Precharge Not Supported
Auto-Precharge Supported
Precharge All Supported
Write1/Read Burst Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Not Supported
Redundant Row Address Not Supported
Senor:Sensor Properties
Sensor Type Asus AS99127F
Sensor Access SMBus 2Dh
Temperatures
Motherboard 32 °C (90 °F)
CPU 32 °C (90 °F)
Cooling Fans
CPU 2071 RPM
Chassis 4018 RPM
Voltage Values
CPU Core 1.68 V
CPU Aux 2.58 V
+3.3 V 3.42 V
+5 V 5.05 V
+12 V 12.40 V
-12 V -11.89 V
-5 V -5.13 V
Video Adapter Properties
Device Description 3dfx Voodoo3
Installed Drivers 3dfx16v3.drv
Video Adapter Manufacturer
Company Name 3dfx Interactive, Inc.
Product Information http://www.3dfx.com
Driver Download http://www.voodoofiles.com/3dfxhelp.asp
Well, theres my comp..... My budget for a new cpu is ~1000 canadian.
You can do so much better for so much less. Check out the FS/FT forum for rigs people are selling. Your rig is just plain wrong.
yeah its almost five years old... believe it or not it was purchased for over 2.5k....... brings tears to my eyes....
also: i want to be able to game at least cs at +90 fps. being able to play cs source and hl2 would be a plus..... but i dont think i am going to get it OR doom 3. i think the classic cs is good enough so if i have a comp that can go +90 fps on cs without every dipping under 70, ill be happy.
go with an amd 2500+ rig. that'll be around $400-600 USD and will play what you want pretty nicely.
see my sig....built it for HL2 will add a 6800 ultra Nov. 16 ! it should be able to handle anything I throw at it !.....OC'd the 2.6 to 3.0, but I may change that as well !....my version of an UGC !
I dont think a 6800 ultra is within his budget...
get rid of all that crap about each component and just give us the basic parts list
Seriously, all we needed to know was you use a P3, a voodoo3, and had 128 MB RAM. All the other stuff we could've gleaned (as in: old :p )
It's been a while since I've recommended systems...
With $1000 CDN, possibly
Athlon XP Barton
Asus A7N8X
512 MB RAM
Some hard drive
A Lite-ON CD-RW
Some case
Some power supply
Windows XP Home OEM
Err, what's a budget vid card these days? Radeon 9800? I dunno.
That would probably be within your budget, but I don't know prices of Canadian stores.
Say he has about $830 USD to mess with.
Agree completely with a Barton and 512MB
If he could squeeze in a 9600xt or better yet a high end GF 5700 variety I think he would be golden.
Eh, just screwing around on the egg....:
2600+ barton retail
Asus a7n8x
9600xt
512 corsair
windows
total $550
now add: $50 case/ps, $50 CD &floppy, $60 40gb HD, shipping, etc
Pretty good system for the ballpark eh?
mobo:http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=50371&CatId=1377 240$$
athlon 3200+http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=627472&CatId=1374 240$$
200 gb hdd: http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4497&CatId=1384 150$$
Ati radeon 9800 pro 128 mb: http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=578354&CatId=1381 323$$
Ram: http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=529656&CatId=856 ~124
as fore a case.... i dont know... i have 50 dollars, or i could always just get a nice power supply and fan and use my case...... its pretty nice. any comments or critique on this system i posted? or should i go ahead and buy i
edit: :eek: no ram!
another edit:fixed... comes out to 1080....... o well.....
wow if u pay 240$ for that motherboard u need to consider killing yourself and tigerdirect. look at ncix.com and vibecomputers.com there both pretty good. Extreme-pc.ca is also a pretty good store.
I say, go for a Socket 754 motherboard with compatible Sempron processor. The Sempron has great IPC like the Athlon 64 does, plus you have the option to upgrade to as high as the Athlon 64 3700+ if you get some more money.
