D
Deleted member 12106
Guest
I have decided I am going to start to build to a dedicated storage server. I currently use WHS and have 14tb of storage, however, I would like to move to something with less overhead, quicker, and more appropriate.
I am going to use a norco 20 drive case, windows 2008r2(installed on 2.5" drive", and will use either this sempron setup I have or a core2 setup I have.
The part where I am more concerned is the controller/expanders. I am not after break-neck speeds since this is going to be used primary in my house and will stream content to laptop/extenders.
Because I do not have the up-front cash to do this in one shot, I am shopping for the small items first. One of those is the controller.
I want to be able to run a 40 drive array, and have the ability to run another array externally down the road.
One of the cards I am looking at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816115056&cm_re=4320-_-16-115-056-_-Product
Highpoint RocketRAID 4320
This looks like a unit I can use a sas expander on and run 40 drives in a norco, and also expand externally if needed.
What are other cards I should be on the look out for?
