I'm building a computer for a friend, and he has a budget of $1200 max.
So far, this is what I have been able to put together in newegg:
Mobo: GIGABYTE GA-EP35-DS3L LGA 775 Intel P35 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128337
89.99
CPU: Intel Core 2 Duo E8400 Wolfdale
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
194.99
HSF: ZALMAN 9500A
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
48.99
GPU: XFX 8800GT 512MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150252
179.99
Memory: CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
85.00
PSU: CORSAIR CMPSU-550VX 550W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
99.99
HD: Western Digital Caviar SE WD3200AAJS 320GB 7200 RPM SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136098
66.99
OS: Windows Vista Ultimate 64-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116215
170.00
Optical Drive: Pioneer 20X DVD±R DVD Burner Black IDE
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129018
29.99
Total so far is around $970. I'm letting him choose the case (should be another $150 - total would then be $1120), + shipping (estimating this to be $50 to me and another $50 to him - i'm in TX, he's in CA, mainly to avoid taxes
I will be shopping around for better prices on these components, but I would just like to ask you guys if I should change anything.
With shipping and everything, it should come out slightly over his budget, and he might be ok with that. Thanks a bunch for looking at this and expecting good advice from [H] readers.
89.99
194.99
HSF: ZALMAN 9500A
48.99
179.99
85.00
99.99
66.99
170.00
29.99
