Building a PC for my kid
digitalgunfire
Looking for some suggestions to keep costs down. He is 6 going on 20 and loves video games. We'll probably play Torchlight 2 together, he likes things like Terraria, MineCraft, Costume Quest, stuff like that.
I have a spare 24" monitor kicking around which does 1920x1200 I'll probably use for it. I'm not opposed to upgrading my GPU to a 680 or 7000 series Radeon and giving him my 570GTX also.
However, I'd like to not spend a fortune on this box - it's not like he is going to care about AA or AF and he'll be happy to just have something to play on.
What say ye? I was thinking something like an X4 Phenom, 4GB of RAM, either upgrade and give him my 570 or get him something like a 560.
Gaming for my kid.
No set amount but trying to keep the costs down, 500-600 max would be super.
US, Wisconsin
Case, PSU. Motherboard, CPU, RAM, HD, DVD-ROM, possibly video card if I don't upgrade mine in the process of building this.
1920x1200 monitor, possibly a 570GTX.
6) Will you be overclocking?
Nope.
24" 1920x1200
Sometime soon. 2-4 weeks max.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Don't care too much, price trumps features at this point. Don't need RAID, firewire, Crossfire. UEFI is cool but whatever.
Yup, 64bit Win7.
Well if you can buy before the 31st, I recommend this setup:
$125 - Intel Core i3 2120 + LG GH22NS90B SATA DVD Burner Combo
$50 - Biostar H61MGC Intel H61 mATX Intel Motherboard
$41 - Crucial CT2KIT51264BD160B 2 x 4GB DDR3 1600 RAM
$135 - Sapphire 100315L Radeon HD 6850 1GB PCI-E Video Card
$85 - Hitachi 7K1000.D HDS721050DLE630 500GB 7200RPM SATA 6.0Gb/s Hard Drive
$48 - Antec NEO ECO 400C 400W PSU
$50 - NZXT Source 210 Elite Black ATX Case
Total: $534 shipped
If you end up buying in April, bump up the thread then as my build recommendations may have changed then.
i really doubt he'll need a 560 or 570.
it sounds like, he should be fine with the built in graphics of any sandybrdige. or if you'll wait till april. ivybridge will be even better.
even the 6850 should be overkill from the games you listed...
It probably is. But that particular HD 6850 is probably one of the better bang for the buck GPUs out now. the next step below the HD 6850 is the HD 6770 which costs $118 for the cheapest good one. The price difference is small yet the performance difference is large. Hence why I recommended that HD 6850, even if it's a Sapphire and overkill.
i think even a $50 discrete should be more than enough.
if the OP doesn't care about future upgradability, fusion is probably the best choice right now.
if you want more future-proof, go with sandy/ivy bridge integrated for now, and drop in a card later if gfx performance is slow.
remember. Terraria, MineCraft, Costume Quest, etc, these games are not like games you might be thinking of, starcraft 2, wow, bf3, etc etc.
Not really. An Intel Pentium G620 or G840 CPU + HD 6670 outperforms even the highest-end Fusion CPU in most games.
Fair enough if the OP wants to do that.
But it's at 1920x1080 though. That's still gonna require some GPU power.
