Building a PC for mom's bday
DeltaD
Her computer is 10yrs+ old so it'll be a nice upgrade.
web browsing, email, watching/streaming movies, very basic PC
$200 but pretty flexible, can even go to $300. Tax/shipping not included
3) Where do you live?
Dallas, TX - I have Frys & Microcenter nearby
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU - preferablly i3
MOBO - no idea
DDR3 RAM - 2GB+
PSU - CORSAIR? ~400w
CASE - $30 @ Microcenter
Optical Drive, Mouse, Keyboard, 500GB HDD, Radeon HD 5670
6) Will you be overclocking?
no
would like a 23”+ for less than $150 (not including in the original $200 price)
next few weeks/ august. I can wait for cheaper parts
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
none. USB 3.0 would be nice
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
win 7 Home 64bit
Which $30 case from MC are you talking about?
http://www.microcenter.com/single_product_results.phtml?product_id=0340862
[ame="http://www.amazon.com/Thermaltake-Black-Plastic-Computer-VM30001W2Z/dp/B003SNJA8O"]Amazon.com: Thermaltake V4 Black Edition SECC/Plastic ATX Mid Tower Computer Case VM30001W2Z (Black ): Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31EcWXUcA6L.@@AMEPARAM@@31EcWXUcA6L[/ame]
basically, I just need a MOBO suggestion... the rest I can figure something out. But any help appreciated. thanks!
are there any combo that I'm unaware of? Or anyone know of any deals coming up?
$100 - Intel Core i3 2100 from Microcenter
$80 - BIOSTAR TH67B Intel H67 mATX Motherboard
$34 - G.SKILL Value Series 4GB F3-10600CL9S-4GBNT DDR3 1333 RAM
$35 - Antec Earthwatts Green EA380D 380W PSU
$40 - Thermaltake V4 Black Edition VM30001W2Z ATX Mid Tower Gaming Chassis
Total: $289 plus tax and shipping
Here's what I got so far... PLEASE CHECK and see if everything will go together
Motherboard - Free with AMD CPU @ Microcenter
ASUS M4N68T-M V2 AM3 NVIDIA Geforce 7025/nForce 630a Micro ATX AMD Dual Channel 16GB DDR3
CPU - $90 @ Microcenter; unlockable to 4cores
AMD Phenom II X2 560 Black Edition Callisto 3.3GHz 2 x 512KB L2 Cache 6MB L3 Cache Socket AM3 80W Dual-Core Desktop Processor HDZ560WFGMBOX
RAM - $34 shipped @ Newegg
G.SKILL Value Series 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model F3-10600CL9S-4GBNT
Item #: N82E16820231421
PSU - corsair tx550w. I'm buying a tx750w for $75 (used, but "like new") and giving her my 550w.
and I'll just reuse a crappy case. That'll bring it to about $200!
Also will buy this 24" refurb asus monitor for $90 shipped whenever it's in stock...
The motherboard is a poor choice since it's uses a Nvidia chipset which means it's less stable, less reliable, lower performing, and less supported than AMD's chipsets for AMD CPUs. Try to find a mobo that uses an AMD chipset.
Just curious. You building it for your mom or you? A tough lesson to learn is getting what the receiver needs/wants, not what the giver wants/needs.
Having said that, Danny Bui's suggested build is solid and would be an excellent PC for a long time. The AMD stuff is already old technology. Your mom would only be getting a newer PC, not new.
A good compromise might be using his suggestions in your old case, with your old PSU.
I thought I saw in Microcenter's ad this month that they're selling a motherboard for $20 with the Core i3-2100. Just checked again, see the lower left hand corner of page 4 of their ad.
So for $120+tax you have a Core i3-2100 with a motherboard.
Then $35 for a single 4GB stick of RAM (leaves room to upgrade later.)
Another $35 for the PSU Danny suggested.
And $40 + tax for the case you found at Microcenter.
So you'd be looking at $230 before taxes. A little over your preferred budget but not by much.
Note: If you want USB 3 on this system you'd have to do it via an add-in card.
I told yall I know NOTHING about Mobo. Been out of it for a long time. So thank you so much for pointing that out.
yall think a 380W PSU can run a Radeon HD 5670 stably?
tonynnt is referring to this mobo, which doesn't have that many reviews
MSI H61M-P23 (B3) LGA 1155 Intel H61 Micro ATX Intel Motherboard
Also, can someone explain the difference between mATX and ATX, other than size. I keep thinking that the price vs performance would be better in an ATX size, since you don't have to worry about space.
Thank you in advance! Yall are great help!
A 380W PSU is more than enough for the higher performing and power using HD 5770 so yes it's enough for the low power HD 5670.
Pretty size difference and a lesser amount of expansion slots (4 VS 7 of ATX) are the big difference. Go with that MSI mobo.
just visited Microcenter and they're sold out of the i3 on the first day... :-\
