Right, so at the moment it's looking like I might spring for a system upgrade. My current one is an Athlon 64 X2 6000+ that I've had overclocked to 3.2 GHz stable for the last couple of years; however, it's starting to show its age a little bit as games are becoming limited more by my CPU than my GPU (8800 GT; I game at 1680x1050 so unless I turn on AA there aren't any issues). With Fermi coming out next year I'm waiting on the GPU upgrades anyway, so it's not like I need to wait and save up for one of those. I have a few questions regarding my potential new build.
I guess the big issue for me is, how much of an improvement can I expect going from my 6000+ with 2 GB of RAM to a Core i7 920 with 6 GB? Is the $700ish asking price really justified? I know the X58 platform has upgrade potential, so that's a factor for me, but what kind of improvement can I expect in both games and general system use, aside from the obvious multi-taksing benefits that come from having more memory? Some benchmarks I've looked at have suggested I could see a huge improvement to my minimum framerates, close 40% or higher (the most important, since I usually get 50-60 average but with very noticeable drops in many games), but I'm dubious of them.
Second of all, I've been looking into memory. It gets cheaper every single day, it seems, and I'll definitely be going for a 6 GB kit. However, one thing I'm not sure about is whether or not I need to go for modules with a very high speed. According to articles I've read, there is some scaling potential at higher speeds, but it doesn't make a significant improvement. I've been looking into DDR3-1333 for its balanced cost, performance and overclocking potential, but since I do plan on overclocking, I'm curious if it's worth the money to invest in more. I'm not looking for bragging rights and a few more points in 3DMark, just a noticeable improvement to my computing. I'm also wondering if there is a significant difference between manufacturers when it comes to memory. In benchmarks, Patriot, OCZ, G.Skill etc. all appear to be nearly neck-and-neck, but their price can vary quite a bit. Is there really any reason not to get something cheaper, if it's a reputable brand?
Last, a couple short notes. I've got a Corsair HX-520W power supply which is serving me very well. I assume that it's all I need for a Core i7 920 and a single GPU, and will do just fine even with overclocking, but if anyone thinks otherwise, let me know. I've also got an Antec 900 case, and since I plan on getting an aftermarket heatsink, am I going to run into issues with space? I don't want to buy a new case and I'm not sure if I can accommodate a Thermalright Ultra-120, so if there's anything that performs well but is a bit smaller, I'd love to hear about it.
Oh, the motherboard I've decided on is this one:
GIGABYTE GA-EX58-UD3R LGA 1366 Intel X58 ATX Intel Motherboard
It's fairly fast, overclocks decently, but my biggest concern is the price - I don't think there's a cheaper Core i7 motherboard that performs as well and has the same feature set. Unless anyone has any horror stories about it, I'm going with one of them.
Sorry for the long post, but I'd appreciate any answers that you guys can provide. It's been a while since I've built a system and it's never something I take lightly.
