Hey guys, sorry if this is the wrong forum, but I am building a new rig very soon. I have put some parts together on a 1.5k budget. I would really apreciate any feedback or advice you guys can give. I plan to play most of my games @ 1920 x 1200. Hopefully, that will include Crysis (I can dream), but if not I would like to come close.
GPU - 2x ATI HD3870 Crossfire -
http://www.newegg.com/Product/Product.aspx?Item=N82E16814241067
CPU - Intel Q6600 OEM -
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115018
Heatsink - Thermalright Ultra-120 -
http://www.newegg.com/Product/Product.aspx?Item=N82E16835109125
Motherboard - Asus P5E x38 -
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131219
Case - Antec 900 (already purchased) -
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021&Tpk=antec+900
PSU - OCZ 700W -
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002
RAM - 4GB DDR2 800 OCZ Reaper -
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227267
HDD - WD Caviar 500GB 16mb cache -
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
OS - Windows Vista 64bit home premium OEM-
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116204
Questions:
-Is the PSU enough?
-Is the P5E a decent mobo?
-Is Crossfire support good on the p5E?
-Do you think Crossfire is the right way to go in gaming above 1080p?
-Is the Thermalright Ultra-120 I selected the right heatsink to get? (Isn't there some sort of extreme version? It does not say, but the dimensions match up. Can someone confirm that this is the extreme version?)
Thanks in advance.
EDIT: It turns out that the above heatsink is not the extreme version. So, I guess I am going to have to get it at Frozencpu.com:
http://www.frozencpu.com/products/5...20_eXtreme_CPU_Heatsink_-_Socket_775_AM2.html
However, does anyone know of a reliable site I can find it pre-lapped?
PSU - OCZ 700W -
Questions:
-Is the PSU enough?
Thanks in advance.
