building a new SB Rig
maverick786us
I will be upgrading my old Pentium D rig (not mentioned in my sig) into a new Quad Core gaming rig
A: Multi Purpose Gaming, Movies, Porgramming, Photoshop
A: It can Vary from 1500 - 2000
A:
a) CPU: 2600K I would like to OC it @ 4.5 to 5.0 but want to keep it stable and long lives
b) Mobo: want a good OCing board with good cooling / Fan mechanism. So it going to be Asus P8P67 Pro / Deluxe or Gigabyte P67A-UD7??
I won’t consider spending more than 250 bucks on a Mobo
c) RAM: 2 X 4 GB 1600 RAM with good speed, good latency and shouldn’t be pricy, the best option I consider is G-Skill Ripjaw or Corsair Vengeance.
Note: Apart from gaming I will do programming and most often use Virtual PC with Visual studio and Share point, that’s why need 8GB RAM
d) GPU: I want to play games @ 2560 X 1600. So the best options that I consider are
i. HD 6950 (later X-Fire)
ii. HD 6970
iii. GTX 560Ti SLI
e) Display: Dell u3011 or HP ZR30W
f) HDD: WD Caviar Black 1TB. Right now SSDs are still pricy. If I want to go for an
SSD I won’t consider anything less than 128 GB. So I will buy an SSD 6-8 months down the line when their prices further go down
g) PSU: Corsair AX850 or HX850 ?
h) Case: 650D or 800D. Since I want a solid case with enough airflow so that multiple GPUs get enough room to breathe, and it should be stylish in look and feel.
i) Heat Sink: Again I want my CPU to be under stable voltage, live longer life, I know CPU life is longer, but I don’t want it to start degrading somewhere within 5 yrs or so if I OC it @ 4.5 – 4.8 GHz.
In order to keep CPU healthy a good heat sink in order to keep its temperature low. Now the options I am considering are
i. TRUE 120 (Air Cooling)
ii. TRUE Venomous (Air Cooling)
iii. Corsair A70 (Water Cooling)
iv. Corsair H50 (Water Cooling)
v. Corsair H70 (Water Cooling)
j) Audio: Corsair 2500SP or a Sony home theater System (that would cost almost the same)??
A: Power Supply, Case, display and Heat Sink (if possible)
6) Will you be overclocking?
A: Want to OC while gaming and while performing any high end task. But for normal usuage it want the frequency to be low for longer life
A: 30 Inch
A; March / April
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
A: All
A: No but I can purchase one on student's Account for Windows 7 64-bit Home
Seriously, which features do you need in a motherboard? "All" doesn't help us and we understand that you want a board you can overclock with.
Better yet, revisit this thread about three weeks before you plan on starting to build.
1) RAID: I will put my primary Hard Drive on RAID. I guess now a days every good Mobo comes with RAID0 and RAID1
2) Firewire: Its not a need but sometimes there are some external devices that are fixed on Firewire port
3) Crossfire / SLI: In order to game @ 25X16 resolution no single GPU can play today's game t this resolution with all the settings high, therefore I need to SLI or X-Fire
5) USB 3.0? Since the launch of SB, USB3.0 and lightpeak will become the new standard making USB2.0 Obsolete.
6) SATA 6Gb/s? Just like USB 3.0 every new storage is desinged for Sata 6GBPS standard.
I think the 2 mobo choices I've listed should contain most of these features. I have to pick one of them therefore need your suggestion
Well the problem is that you're planning on buying in Mar/April. So basically, whatever parts recommendations we make today will probably not be the same parts we recommend in Mar/April. Especially due to the all teething issues that many Sandy Bridge setups are now facing.
In other words, no point in making a recommendation right now when you're 90% likely to end up with mostly different parts in April.
Now if you were planning on buying in January, I probably would recommend the Pro. But there might be better Asus mobos 3 months from now judging from the current lineup and issues.
So your best bet for UP TO DATE advice would be to ask again 2-3 weeks before you actually buy. If you want OUT OF DATE advice then by all means continue with this thread.
