Building a new rig, need suggestions
refraxion
Hey, I'm currently planning on making a new rig and need some suggestions on the parts.
Currently I'm planning on getting this:
CPU: Intel Q6600
Mobo: Need help on this one, I'm switching from AMD and I do not know anything about Intel 775 motherboards.
Ram: Which ones are good at a decent price? I'm aiming for 4gigs, (2x2gig sticks)
Video Card: 8800GT 512mb, is an eVGA Superclocked better than a BFG OC?
HD: 74gb Raptor (from old comp)
PSU: Which PSU is good and can handle an 8800gt? I'm thinking an Enermax Infiniti 650W
I'm shopping at this site (from Canada).
http://www.memoryexpress.net
Any help or suggestions is much appreciated, thanks :)
Hi there,
First off, are you willing to wait for a couple of moths or so for newer, faster, better overclocking processors to come out?
If that was the case, a Q9450 would be the choice.
Presuming that you were to buy now, Q6600. For the motherboard, it depends on your requirements. I would say that the Asus P5K-E, Abit IP35, or Gigabyte P35-DS3R are all great choices.
4GB of memory: http://www.memoryexpress.com/Products/PID-MX19221(ME).aspx (You need a 64 bit OS to use this)
The 8800GT: I would just buy a stock clocked card, they are quite a bit cheaper and easy to overclock yourself anyway.
Finally, the power supply, just buy a Corsair HX520.
Thanks for the help!
The motherboard's you have named, I don't think that site sells them, and I'm not sure where I can get those locally, (I'm from Edmonton) Canada.
Also, for that corsair HX520, there are 18Amps per 12V rail, are they cumulative? so instead of 18amps, it would combine for a total of 54amps? Because the 8800GT needs 22-24 amps on the 12V rail to function doesn't it?
I'm kind of reluctant to go the Vista route, has lots of problems been fixed, how well will the 8800GT fair in Vista gaming? Thanks :)
I found the motherboard at another local store and I was wondering if this MoBo was any good, the Asus P5K-E, was it the one you suggested?
http://www.b-com.ca/product.php?productid=219464&cat=297&page=1
Also can anyone help me with the PSU? Is the HX520 really good enough to run the 8800GT? Thanks a lot :cool:
Also, for a Q6600, is DDR2 800 Ram good enough? Trying to make a decent gaming rig. Thanks! ;)
Yes the Corsair 520HX is good enough to run the 8800GT. Also, the amps aren't cumulative.
You determine the amperage on the +12V rails by first finding out what's the total combined or max wattage set aside for the +12V rails/section alone. So for example, the Corsair 520HX has 480W total on the +12V rail. Divide that total wattage for the +12V by 12 and you get how much amps the PSU has on the +12V rail. In this case, 480W divided by 12 is 40A. So the Corsair 520HX PSU has 40A on the +12V Rail. And that's plenty of power for your current system.
DDR2 800 RAM is all that you need. Remember that C2D systems do not benefit from having faster RAM or having the FSB and RAM at a 1:1 ratio. Here's what I mean:
Multiplier x FSB, RAM Speed = CPU Speed
RAM Speed = 2 x FSB
Q6600:
Multi x FSB, RAM Speed = Clock Speed
9 x 266Mhz, DDR2 533 RAM = 2.4Ghz <== Stock Speeds
9 x 333Mhz, DDR2 667 RAM = 3.0Ghz <== Good OC
9 x 400Mhz, DDR2 800 RAM = 3.6Ghz <== Excellent OC
So even with overclocking in mind, DDR2 800 RAM is all that you need.
Ah, thanks for the informative post!
Would the ram I was suggested to get and the asus p5k-e (A good mobo?) Any good? Thanks a lot again, am thinking of picking up the parts sometime this week or next. I've been out of the loop for a few years so I'm really not sure what parts are good price/performance wise :p
The RAM is a good choice. Mobo, I'm not a fan of Intel Asus mobos since they're usually overpriced IMO. With that said, it's a good choice if those are the only two stores you can buy from.
Anyway reason why you're not ordering from these other Canadian sites?:
www.ncix.com
www.canadacomputers.com
Hmm, it's mainly because I rarely shop online and don't like waiting very much :(. So the Mobo is good but just a bit overpriced? Thanks for your replies, I really appreciate it.
The P5K-E is fine. Its not as overpriced as their other offerings, lol. NCIX and Canada computers both have physical stores, no? Eh, but you might not be near them... look into it anyhow. The Corsair 520W is more than enough for your system, so you're good there.
