Building a new PC
Gaming,Multitasking(Browsing the internet and such), Programming
I would like to keep it between $2000-$2500
I'm by Kansas City, MO
Windows 7 64bit OS
CPU
Motherboard
Memory
2x or 3x Video cards
Power Supply(I do have a Silverstone Stryder 850W Fully Modular PSU)
3xMonitors(would prefer 5760x1080 resolution all together)
Computer Case(I do have an Antec 900 but I want to make sure its plent cool and I think I want more room!)
CPU Cooler(I've toyed with the idea of going water cooled but not sure if I could fit it in my budget)
Data Storage HDD
SSD for boot drive(RAID 0) maybe?
Antec 900 Case(Thinking I may want more room and air flow...unless water cooled in which case I know I'll need more room!)
6) Will you be overclocking?
Yes I plan on overclocking
Looking for 5760x1080 and anything between 21.5-24inch
This coming week!
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
The option for RAID, SATA III, and the option for Tri-SLI or CrossfireX
No I need to purchase a new OS because I'm currently running XP 32bit
I'm not really a fanboy either way when I comes to CPUs or Video Cards but from what I've been reading I think I've narrowed it down to the i5 2500k Sandy Bridge for CPU and I think I want to go with NVidia for Video Cards because of the better driver support other than that I'm open to any all suggestions thanks
Prelim setup:
$600 - Intel Core i7-2600K CPU + MSI N560GTX-Ti 448 Twin Frozr III PE/OC GeForce GTX 560 Ti 448 Cores 1280MB PCI-E Video Card Combo
$295 - Asus P8Z68-V Pro/GEN3 Intel Z68 ATX Motherboard + Windows 7 Home Premium SP1 64bit OEM Combo
$374 - MSI N560GTX-Ti 448 Twin Frozr III PE/OC GeForce GTX 560 Ti 448 Cores 1280MB PCI-E Video Card + Corsair Vengeance CML16GX3M4A1600C9B 4 x 4GB DDR3 1600 RAM Combo
$190 - Crucial M4 CT128M4SSD2 2.5" 128GB SSD
$126 - Hitachi Desktar 7K1000.D HDS721010DLE630 1TB SATA 6.0Gb/s Hard Drive
$18 - LG iHAS124-04 DVD Burner
$140 - Corsair Carbide Series 500R ATX Case
$65 - Antec Kuhler H2O 620 Liquid Cooling System
$510 - 3 x Asus VH236H Black 23" LCD Monitor
Total: $2318 plus tax and shipping
From everything I've read in other forums, I need more VRam to run at the resolution I want too. You think the GTX 560 will be able to pull good FPS at that resolution with only 2.5GB of VRam?
I was thinking of a setup something like this
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119213 ~ Coolmaster HAF 932 Blue Addition
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148834 ~ 2TB Seagate HDD for Data
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236175 ~ 3xASUS 23" Monitors
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130739 ~ 3xGTX 560TI 448Core Classified
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130655 ~ 2xGTX 580 3GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171055 ~ Coolmaster 1200W PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226219 ~ 2x4GB Mushkin DDR3 1600MHZ Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070 ~ i7 2600K Sandy Bridge
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442 ~ Crucial M4 128GB SSD for Boot Drive
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.791361.13-157-269 ~ ASRock Z68 Extreme 7 with NF200 chipset :)
Build totals: $2921.36 Shipped
With 2x GTX 580 3GB: $3121.02
I know this is over my original budget but I think this is the one I feel most comfortable with...but I may just go GTX580 3GB in SLI instead so I can either step up the 600series cards or just add a third later for more power...the difference is a couple hundred though
Actually, it's 1280MB of VRAM total. With SLI or Crossfire, VRAM isn't additive.
In any case, the GTX 560 TI 448 Core should offer good FPS but probably not at max settings. Unfortunately, due to your insistence on Nvidia, your budget and the market, the GTX 560 TI 448 Core 1280MB is your best bet if you want Nvidia. If you want more VRAM within your budget, you're looking at AMD (HD 6950 2GB Crossfire or HD 6970 2GB Crossfire) or up the budget to fit the GTX 580 3GB.
Overpriced IMO. That case actually makes the overpriced Coolermaster HAF X look like a good deal.
Only gripe I have against this drive is the short one year warranty.
I'd go for the GTX 580 3GB if you're playing BF3 or Skyrim as those games can take advantage of the VRAM
I'd spend the extra $30 for an increase in quality:
$270 - Antec High Current Pro HCP-1200 1200W Modular PSU
Overpriced just a tad: A lot of RAM with similar specs are priced around $35 to $40:
$35 - Patriot Signature PSD38G1600KH 2 x 4GB DDR3 1600 RAM
I don't recommend this mobo on account of the short 1-2 year warranty and the poor HardOCP reviews of other AsRock Z68 mobos:
http://www.hardocp.com/article/2011/12/07/asrock_z68_pro3_lga_1155_motherboard_review/
http://hardocp.com/article/2011/11/09/asrock_z68_extreme4_gen3_motherboard_review/
I would not go Tri-SLI with only a 1.2GB card. Too easy to run into VRAM limitations before you run out of GPU horsepower, especially at eyefinity resolutions.
Yeah I decided I'm gonna go SLI with the GTX 580 3GB version and maybe upgrade the Tri later
My step brother offered to buy my current setup for $500 so I got some extra cash to put in my new build
Okay I think I've finally narrowed down my build to what I want to get
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119213 ~ Cooler Master HAF 932 Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072 ~ Intel i5 2500k CPU
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.791361.13-157-271 ~ ASRock Extreme 3 Gen3 Z68 MOBO and Windows 7 64bit combo
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130655 ~ 2 x EVGA 580GTX 3GB in SLI
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139034 ~ Corsair HX1050 PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231461 ~ GSkill DDR3 1600 2x4GB Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145533 ~ Hitachi 1TB HDD for Data
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442 ~ Crucial M4 128GB SSD for Windows and some games
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204 ~ ASUS DVDR
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254058 ~ 3 x 21.5" Hanns-G LED HD Monitors
Total: $2730 Shipped (May make the trip to KC to get the i5 for $180 at Micro Center if its in stock when I head that way)
Also...
http://www.frozencpu.com/products/1...CPU_Block_Universal_Mount.html?tl=g30c321s818 ~ Swiftech H20-320 EDGE Water Cooling Kit
http://www.frozencpu.com/products/1...cidal_PC_Coolant_Additive.html?tl=g30c103s186 ~ Biocide
Total: $305 Shipped
For grand total of $3035 Shipped (I originally didn't want to go above $2500 but my step brother offered to buy my current rig for $500 so I figured I'd just drop it into my new build
I'm eventually going to water cool my video cards and maybe the whole PC but I'm gonna see how it goes with just the CPU for now since this will be my first venture into water cooling!
You do realize that ASRock motherboard only has a 2 year warranty, an as such there are better longer warrantied motherboards out there for the same price or cheaper.
Ordered the parts this morning from newegg...
Master Cooler HAF 932 Full Tower Case Blue Edition
3x Acer 21.5" 1080p LED Monitors
2x EVGA 580GTX 3GB Video Cards
1050W Corsair PSU
ASUS P8Z68-V MOBO
Intel i5 2500k Sandy Bridge CPU
Cooler Master 212+ CPU Cooler ~ Artic Silver 5 Thermal Paste
2x Scythe 120mm 'slip stream' fans for CPU Cooler
1TB Hitachi HDD
128GB Crucial M4 SSD
Sony DVD Burner
Window 7 Home 64bit
Grand total $2800 Shipped will post pics and benchmarks when I have it setup!
Decided against water cooling since I don't wanna mess up and end up with a $3k paper weight
