Building a new PC, what do you think?
Sup everyone!
As the title says, I'm in the process of building a new PC. This would be my third build. Starting fresh. No over clocking, plain stock. Mostly for gaming, but a little programming here and there. Trying to stay under $1200. After about a week or two of research and what not, I have come to configuration
https://secure.newegg.com/NewVersio...istNumber=1577693&WishListTitle=Dream+Machine
Just a newegg wishlist. Wondering if anyone could go over it and tell me what you think or if I'm missing something? If you notice, I have liked AMD for as long as I can remember. I guess old habits die hard even though I know the core 2 kicks ass right now. BTW, if you know of any LCD ~$150ish that would be great.
Asking for the humble opinion of the HardForum experst! Thanks!!
You can save yourself $40 or so by going with the Sapphire built x1950Pro here: SAPPHIRE 100176L Radeon X1950PRO 256MB PCI-Express - $169.99
And do you have a need for Crossfire? Like SLI, Crossfire is not an effective method of upgrading. There will usually be a better single card solution than two mid-range cards in SLI or Crossfire but at a cheaper price.
I'll leave the "convincing you to switch to Core 2 Duo post" to someone else.
buffbiff21, I had the same issue. What I did was make my list public and use the email wishlist link that should be to the right of the wishlist, that way I could copy the link and post it here. Please, I would really like to take a look at it!
I forgot to mention Danny Bui, that I don't plan on using Crossfire/SLI anytime soon. But I couldn't find any other motherboard with the AMD/ati chipset going on. I'm pretty sure I can run a radeon on nforce chipset, right? Anyone have any real life exp. doing that?
I would really appreciate it if anyone can tell me what you think of that AMD setup I have going on, the if you can be so cool as to give me the heads up on a Core 2 Duo.
Sorry for all the questions. I'm afraid of "investing" too much into this build and not get much out of it. Thanks everyone for the replies! Keep them coming.
Yes you can use an ATI card with a mobo with an Nvidia chipset. It would be really retarded of motherboard manufacturers to force you into using only the video card of a specific manufacturer.
As for your AMD build, it's a decent system but it'll get owned by a Core 2 Duo system. For a Core 2 Duo build, just keep everything from your AMD build but instead of the AMD CPU and mobo, go with this setup:
Intel Core 2 Duo E6400 - $221.00
GIGABYTE GA-965P-DS3 Socket T (LGA 775) Intel P965 Express - $122.99
Total: $344 plus tax and shipping
If you check out this chart here: http://www23.tomshardware.com/cpu.html?modelx=33&model1=433&model2=696&chart=191 Make sure you look though the benchmarks.
While the Athlon 64 X2 5600+ is close behind the E6400 in several benchmarks and in some benchmarks, beats it, the E6400 costs only $221. The Athlon 64 X2 5600+ costs $329. The fact that it takes an extra $100 to beat the E6400 should change your mind about buying AMD.
Don't forget a good power supply; zipzoomfly.com has the corsair hx 520 for only $96 after mir with free ship.
