Building a new PC, opinions please!
Tom B
I haven't built a PC since the one in my sig.
I'm looking to build a new PC, I only need Motherboard, CPU, PSU, RAM and GPU.
Here's what I'm looking at getting but i'm somewhat out of the loop on what's good and what isnt. Is Intel/nVidia still the best way to go? Certainly appears so, and I'm well impressed with my Q6600, still going strong and the 8800GTX still works well... anyway the PC:
Intel i7 920. Seems to be the best bang for your buck i7 chip out there, the higher ones are much more expensive.
Motherboard... I'm undecided.Was looking at the cheaper X58s. Asus P6T or Gigabyte GA-EX58-UD3R or Foxconn Flaming Blade. Any recommendations here are welcome but I don't really think I need crossfire or SLI. I plan on overclocking the 920 to 3ghz though. Asus P6T is my current choice since i've had good experiences with Asus boards before. Though other suggestions are welcome
HSF: In my current PC I have an orignal model Tuniq Tower, works great. What's good nowadays? It can't still be one of the best 2 years on. I don't really want to spend more than £40 on a HSF. The CoolerMaster V8 looks rather good. Again, suggestsions are welcome.
GPU: BFG GeForce 295. Nothing comes close to the 295 and BFG is a respectable brand. My BFG 8800GTX has never had a problem, but i'm open to suggestions if BFG aren't the way to go.
RAM: OCZ Reaper 6GB (3x2GB) DDR3 PC3-12800C7. Just going on price for this one, fully open to suggestions.
PSU:OCZ ModXStream Pro 600w because it's currently on offer at Overclockers.co.uk
This is right on the limit of my budgets, so I can't really make any big substitutions unless they're really worth it.
Any comments/suggestions are very welcome!
It would help if you answered the questions in the sticky titled "ANSWER THESE QUESTIONS FIRST" so that we can help you better.
Sorry...
1) Gaming, mostly. I work as a web designer so need to also need to run photoshop, zend stuido, etc, but I have a PC at work for that really. I don't do that much work at home. Mostly my home PC gets used for gaming.
2) Budget is around £850, can go over but not by too much. That includes tax and shipping
3) UK
4) I need: Motherboard, Processor, PSU, GPU, RAM and Heatsink
5) Only my case (Coolermaster stacker 820), monitors, and external peripherals (in sig)
7) Currently have a two 1680x1050 22" Inch LCDs. Am looking at getting a 1920x1080 22" in the near future though.
8) Within the next few days (Replacing my girlfriends PC that the motherboard fried on with the one in my sig, and getting a new one for myself)
9) Nothing other than standard stuff. Ethernet and SATA. Don't even really need audio. Don't need SLI. I choose the SLI motherboard for this PC "just in case" and never used it.
10) Am currently using Win 7 RC, and have a copy on pre-order :)
Can you provide a more precise time when you'll be getting a larger monitor? As it stands now, the GTX 295 is complete overkill for 1680x1050 but just right for 1920x1080.
HSF wise, see if this HSF is available in your country:
$40 - Thermalright Cogage TRUE Spirit HSF
It performs on par with the TRUE 120 which outperformed your Tuniq Tower. So therefore, the above HSF will outperform the Tuniq Tower.
Mobo wise, go with the Asus P6T SE or the Asus P6T as either of those mobos will fit you needs.
PSU wise, ditch the OCZ. It's not that good of a PSU. In addition, your planned setup requires a PSU with at least 50A on the +12V rail. That OCZ PSU only has 42A on the +12V rail. So I recommend getting the Corsair 650TX with its 52A on the +12V rail instead.
Thanks for your help
The thing with GPUs which are currently "just right" for a resolution is that it doesn't apply in 6-12 months time. My friend got a 8800GT (the original 640mb one) which at the time was "just right" for his 1440x900 monitor, when GTA4 came out, his GPU struggled with it.
I also considered the 8800GT instead of the GTX, and I'm really glad I paid extra and went for the GTX, which is why I'd rather get the 295 and have more longevity.
The only reason I went OCZ on PSU was price, I will take your advice and get the Corsair 650TX instead.
For HSF, I can't find anywhere that stocks the Thermalright Cogage TRUE Spirit HSF. Perhaps they're not out in the UK yet. Any other suggestions?
$40 - Xigmatek Dark Knight-S1283V 120mm HSF
$70 - Corsair Hydro H50 CPU Cooler
$70 - Thermalright Ultra-120 Extreme 1366 RT HSF
I can't find anywhere with those in stock, how does the Xigmatek Thor's Hammer stack up? The coolermaster V8 seems pretty good (http://www.overclockersclub.com/reviews/cm_v8/4.htm ) comparible with the Thermalright Ultra-120 Extreme if that review is anything to go by and it's currently on offer at overclockers.co.uk so think I'll go with that. How does the P8T compare with the Foxconn Flaming Blade?
The Thor's hammer is actually a bit worse than your current Tuniq Tower.
The P6T is better than the Flaming Blade IMO. More stable BIOs, 6 DIMM slots, etc.
