Hello everyone , i'm building a new pc since my old p4 3ghz isnt cutting it anymore. its been exactly 4 yrs and 4 months since i build that pc and its time for a new pc.
Currently i bought
1. XFX PVT88PYDD4 GeForce 8800GT 512MB Alpha Dog Edition 670/1950 http://www.newegg.com/Product/Product.aspx?Item=N82E16814150254
2. Arctic Silver 5 Thermal Compound 12 Grams http://www.newegg.com/Product/Product.aspx?Item=N82E16835100008
3. Arctic Silver ACN-60ML (2-PC-SET) Thermal material Remover & Surface Purifier http://www.newegg.com/Product/Product.aspx?Item=N82E16835100010
4. Thermaltake SOPRANO VB1000BWS Black 0.8 mm SECC Chassis http://www.newegg.com/Product/Product.aspx?Item=N82E16811133145
Total for this was $471.55
Next i need a Hard drive , Psu , Ram , Mobo , Cpu , Gpu and Cpu Heatsinks.
Hard Drive - HITACHI Deskstar 7K1000 HDS721075KLA330 (0A35154) 750GB 7200 RPM SATA 3.0Gb/s Hard Drive - $184.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16822145166
Psu - CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply - $139.99 ( Need A Modular One ) http://www.newegg.com/Product/Product.aspx?Item=N82E16817139002
Ram - CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400 - $64.90 http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
OR --------------------
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory http://www.newegg.com/Product/Product.aspx?Item=N82E16820146565
Mobo - ASUS P5K-E LGA 775 Intel P35 ATX Intel Motherboard - $141.98 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131225
Cpu - Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor - $272.90 http://www.newegg.com/Product/Product.aspx?Item=N82E16835118019
Cpu Heatsink - ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler - $60.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16835118019
Gpu Heatsink - Thermalright Gt Vga Cooler - $49.99
The Total For these parts is $1418.13 ( shipping and tax included )
My budget is $1,500 - 1600 max
Im going to order them from zipzoomfly because its a bit cheaper and i live in california and i dont want to pay the tax ^_^.
I already have a XFI Gamer soundcard so i dont need a new one.
Im gonna be ocing the cpu to hopefully around 3ghz if it runs stable.
Im mainly going to be using the pc for Gaming , Video and Sound encoding and browsing / daily uses. I usually leave my pc running for 24/7 and restart it once a month.
Do you guys think this is fine or can anyone suggest something better in my price range in mind .
I really need some help on some of these parts , what do you guys think so far ? , if you guys have suggestions on other parts or upgrades let me know plz
thanks
The Monitor i currently have is a Westinghouse L2410NM ( Dvi - Hdmi Cable )
Currently i bought
