Building a New PC (ibuypower)
iCrayon
I am currently building a new PC using ibuypower so far I have chosen as follows:
Case: CoolerMaster HAF 922 Gaming Case
CPU: Either Intel® Core™ i5-2500K Processor (4x 3.30GHz/6MB L3 Cache) or
Intel® Core™ i7-2700K Processor (4x 3.50GHz/8MB L3 Cache) I cannot decide because the price difference is only 95$ at the moment
Cooling: Asetek 550LC Liquid CPU Cooling System (Intel) with
ARC Dual Silent High Perfornamce Fan Upgrade (Push-Pull Airflow)
RAM: 16 GB [4 GB X4] DDR3-1600 Memory Module(G.Skill Ripjaws X)
GPU: NVIDIA GeForce GTX 680 - 2GB
MOBO: This is where I am stuck currently I have chosen
ASUS P8Z68-V LX -- Lucid Virtu Technology
PSU: 750 Watt - Corsair CMPSU-750TXV2 Free Upgrade to 850 Watt Corsair CMPSU-850TXV2
HDD: 2 TB HARD DRIVE -- 64M Cache, 7200rpm, 6.0Gb/s
To give some background on what I do, I game a lot, mainly PC/Xbox
I also stream my gameplay on both using the Black Magic Intensity Card that uses another PCIe slot x1,x4,x8, or x16. I'm pretty sure I chose the correct motherboard to fit my needs and to work with the other parts, my main concern is a 2nd opinion on MOBO, and CPU again for 95$ I feel the urge to just step up to the i7 unless someone could otherwise convince me it is a huge waste of money. I currently stream WoW and SC2 on my laptop using Xsplit, been wanting to build another desktop for a while just havent had the time and ibuypower's pricing seems decent enough so I dont have to order each part and do it myself again.
This is [H] man, hop on Newegg, buy some parts and build it yourself. :D
:eek: Yea thats what I did with my last desktop, I just dont really have the time to order, receive, build :(. Normally I would do that but like I said the price is decent enough for me to not build it myself. Just asking for opinions is all ;)
Also for a case I was debating between
or
CoolerMaster HAF 932 Advanced Full Tower Gaming Case
or
Antec DF-85 Full Tower Gaming Case
I hear the HAF cases are pretty good. Haven't heard anything about that Antec but they make good cases in general.
As for your other questions...the i5 2500k is probably plenty for you, but the i7 is definitely better. The i5 doesn't have Hyperthreading, which, if all you do is play games means basically nothing to you. If you do any sort of video encoding, though, it might be worth it.
Dunno about the motherboard. Not entirely sure what your question is about it.
Yep, I wouldnt recommend spending money getting a prefab. Building a PC is quite easy and will save you a shitload of money. Just read a few articles and ask some advice on here. Spending $500+ conservatively more for the exact same parts just seem illogical.
I mean for what I am getting I do agree with the price, and like I said I dont have much time to sit and build myself, also in some cases newegg and other sites were a bit more expensive on parts then ibuypower, im looking at around $1500 right now.
between i5 and i7 is 95$, I possibly could use it for encoding video as well, moreso a friend of mine that would be editing clips and all with me.
My question for the motherboard is the brand, it happens to be the cheapest one of the choices, and seems to fit what I need and has extra slots for my other cards and future expansion
Thank you for the reply btw
Are you set on iBuyPower? If not I'd really like to throw Puget Systems into consideration. They build really great stuff and their Spirit line falls right into your price range.
I've known their prices to be great, but not set on them, I'm definitely open to other options, I'll take a look
Only problem I see, When choosing the exact same build, the spirit line is ~450$ more than on ibuypower for same CPU, GPU, and RAM, thank you for option though, I will still take further look through the site. Thats just what I see so far
You should throw in a SSD as a boot drive, huge difference.
Also I know cases are a personal choice, but those HAF cases are fugly
Ibuypower isn't as bad as people make them out to be, especially if you get in on one of their big sales. A friend of mine got one around Christmas and paid only like $20 than if he bought the parts from newegg with their free build discount. And that was a $1200 computer so it was barely anything more. But it does lack the ability to overclock and customize it yourself.
I would recommend buying the overclock packages though.
lol Im not worried about look, moreso airflow is my main concern, make sure she runs cool, my only issue with SSD is I have heard horror stories of them having half the life expectancy of traditional hard drives unless you shell out 500$+ for a better one.
Anyone else have thoughts on another MoBo or is the one I chose a decent one? I looked up others on this site and it seems that other people have said its a good board
You can't overclock with ibuypower? (CPU)
And Yes I completely agree, their prices are more than competitive, I actually have priced the main parts out on newegg vs ibuypower, and with ibuypowers current sales newegg is significantly higher than ibuypower (~200$ atleast)
Also, I am not too worried about the overclocking, but of course I will be curious to try, however, if I choose their overclocking package of 20% more for 49$, doesnt that mean that I cannot myself overclock it later on?
It looks like they are having quite a few sales, so it may indeed be better for you to go through iBuypower.
That motherboard is fine. If it has all the features you need, then go with it. There are three better versions of that motherboard that have additional features you may or may not need.
I don't see why you couldn't overclock... unless they flash a custom bios or something onto the motherboard.
Yea I'm thinking 1 GPU, and my Black Magic Intensity, and that Black Magic can fit into any pcie slot, If you wouldnt mind maybe showing me, or telling me the better features of the other 2 versions that would be great :)
My only experience with iBuyPower was getting a custom (Compal CL56 or something like that) laptop from them about 8 years ago. Worked great for several years before the video or mobo died or something. Not sure, since there was a lack of parts available for it to diagnose and repair. That was more because it was a semi-obscure brand though, not really iBuyPower's fault necessarily.
They do have some pretty good deals sometimes. I would recommend them for a pre-build.
Might be easier to look at a comparison here of the different versions.
Basically, the better boards have more USB 2.0 ports, more Sata III ports, an Intel Lan instead of Realtek, USB 3.0 ports and SLi/Crossfire support.
Yea my buddy got his desktop and laptop from them, he pretty much only plays wow, and its great for him, the 2 combined were about 1600$. ~800$ each.
I used to work for Circuit City and we had special deals from them back in the day, so thats where I have always looked to pre builds for friends/family.
But I do think for 95$ more I am going to go with the i7 2700k, its not a huge jump in price and I would love to have the extra power if I would ever get into something more resource intensive.
Have you heard anything about their advanced wiring packages? seems worth it for better airflow, its like 19$ for each package ~60$ total and they individually wire everything
I get countless hours of fun messing with my wiring myself in order to achieve the best look and airflow. However, I don't see anything wrong with paying $60 for them to sleeve and route all your cables.
So this Mobo:
Has anyone had experience with Black Magic Intensity?
Im pretty sure this Mobo will be more than enough for both my GPU and BMI, I just wanted to see if anyone had prior experience with BMI, and if I should be getting a better board or if this board is good, I have looked at the others I just wanna make sure, its about an 87$ difference to step up to the next version of the same Mobo
1 x Case ( CoolerMaster HAF 922 Gaming Case - Black )
1 x Processor ( Intel® Core™ i7-2700K Processor (4x 3.50GHz/8MB L3 Cache) )
1 x Processor Cooling ( Asetek 550LC Liquid CPU Cooling System (Intel) - ARC Dual Silent High Perfornamce Fan Upgrade (Push-Pull Airflow) )
1 x Memory ( 16 GB [4 GB X4] DDR3-1600 Memory Module - G.Skill Ripjaws X )
1 x Video Card ( NVIDIA GeForce GTX 680 - 2GB - Single Card )
1 x Video Card Brand ( === High Performance === EVGA Brand Video Card Powered by NVIDIA )
1 x Free Stuff ( [Free] Corsair 16GB USB 3.0 Flash Drive - Free with Any System Purchase over $1499 )
1 x Motherboard ( ASUS P8Z68-V LX -- Lucid Virtu Technology )
1 x Power Supply ( 750 Watt - Corsair CMPSU-750TXV2 - Free Upgrade to 850 Watt Corsair CMPSU-850TXV2 ($20 Savings) )
1 x Primary Hard Drive ( 2 TB HARD DRIVE -- 64M Cache, 7200rpm, 6.0Gb/s - Single Drive )
1 x Optical Drive ( 24X Dual Format/Double Layer DVD±R/±RW + CD-R/RW Drive - Black )
1 x Sound Card ( 3D Premium Surround Sound Onboard )
1 x Network Card ( Onboard LAN Network (Gb or 10/100) )
1 x Operating System ( None- Pre-formatted Hard Drive Only )
1 x Advanced Build Options ( Tuniq TX-2 High Performance Thermal Compound - The best interface between your CPU and the heatsinks )
1 x Advanced Build Options ( Professional wiring for all cables inside the system tower - Achieve exceptional airflow in your chassis )
1 x Advanced Build Options ( Professional wiring for all cables inside the system tower - Basic Pro Wiring )
1 x Advanced Build Options ( Professional wiring for all cables inside the system tower - Advanced - Power Package (Individually Sleeved 24-pin ATX, 8-pin CPU, and SATA Drive Power Cabling) )
1 x Advanced Build Options ( Professional wiring for all cables inside the system tower - Advanced - Video Package (Individually Sleeved 8-pin and 6-pin PCI-E VGA Power Cabling) )
1 x Warranty ( 3 Year Standard Warranty Service )
1 x Rush Service ( Rush Service Fee (not shipping fee) - No Rush Service, Estimate Ship Out in 5~10 Business Days )
That is what I am leaning towards right now
Yeah, that bit of misinformation still gets around unfortunately. Even your regular, budget SSD will last longer than you will use your computer for. If you want one, grab the Intel 520 120GB. Very reliable, and will last a long ass time.
@Op:
The LX doesn't do sli, if you aren't going to do sli why on earth would you get that psu?
You're looking at at most a 400w load, probably more like 320-350w.
I would expect delays because of the video card choice, if you're not a top tier partner, you aren't getting access to those cards. Yes even the custom builders, are having a tough time keeping those cards in stock, a side effect of the paper launch. I have a client that I regularly build quadro dual processor workstations for, who just called me yesterday complaining that his order at strangely enough ibuypower has been delayed twice, he asked me if I would build his son a gaming rig... he didn't think that I would be interested but he asked anyways. He was going sli...but I talked him out of it since his son is going to game on a 1080p TV.
I'm still waiting to see if my newegg order gets canceled for the gtx680.
Pm me your email and I'll send you the build I did via newegg.
I would go with the above poster and grab an SSD drive for your OS and maybe drop to a 1tb or something for a storage drive.
Also, the cases, the HAF Cases are good cases. I don't want to talk you out of them, but I have an HAF912, (which is smaller then both you have listed) and its BIG. More then enough room for a crossfire setup, several hard drives, Corsair H-60 or H-100 and plenty of room to spare. The HAF 922/932 are absolutely HUGE cases and meant more for custom watercooling with tri/quad crossfire/SLI setups. Like I said, I don't want to talk you out of it, but its just A LOT of case for what you have listed.
I would also grab the 2700k. The I-7 chip is a beast right now and it will be that much longer before you need to look at upgrading in the future.
The one experience I've had with ibuypower was a prefab a friend purchased. It wasn't too bad, but there were a few issues. For one they used too much thermal paste. In your case it shouldn't matter as you've chosen a cooler that comes with it's paste pre-applied. The main issue he had was the cable management. It was TERRIBLE. He had to go through and completely redo it as it was restricting airflow and looked like crap. The cable management was basically the part of the build he was trying to avoid and was the reason he purchased a prefab. He might as well of just built his own computer. So that might be something you want to think on... If the cable management sucks you'll probably spend as much time redoing as you wouldn't just building it in the first place.
And lastly, I know their prices aren't bad... But I feel like you could save a few hundered dollars and not have to worry about things like TIM, cable management, bloatware, etc by doing it yourself. Matter of fact right now I know someone sellling;
Core i7-2600K
MSI Z68MA-ED55 B3
Corsair Vengeance 8GB
Thermaltake Modular 750 Watt power supply
WD Caviar Black 1TB HD
Gigabyte 7950 windforce
Zalman CNPS9900MAX-R CPU Cooler
For $1000 shipped. Everything is brand new. The GPU has been taken out and tested and that's all the use anything has.
Just to throw a wrench in your plans, iCrayon:
If you do buy from iBuyPower, inspect every single component - both inside and out - when you receive the system but before you plug it in. You see, iBuyPower (and its parent company CyberPower) are notorious for extremely sloppy and careless assembly quality. Far too many screws have worked their way loose or even have fallen off in shipping, causing serious (and sometimes severe) damage to the system's innards. And one big red flag against them in general is that they continue to offer PSUs that are known to be crappy or even shitty as extra-cost options.
If you see any damage, return the entire system back to iBuyPower for repairs.
