tehslippery
- Feb 17, 2012
A little bit of everything, but mostly doing a lot of boxing MMO's like EQ2 and TOR
Budget isn't a strict issue, but I'm trying to keep it in the 2k range. If I go a little over it isn't a problem
Cape Coral, Florida
Case, Motherboard, Processor, RAM, Video Card, Power Supply, SSD
Hard Drive, 2 Fans that I'll put on H100, I also have a keyboard, mouse, and monitor already.
6) Will you be overclocking?
Yes, I'd like to be in the 4.5 to 4.8 GHz range
7) 7) What is the max resolution of your monitor? What size is it?
1980x1020
I'd like to buy this weekend/early next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
I don't intend to do anything SLI, and don't really use much in the USB department other then peripherals. SATA 6Gb/s for the SSD/HD
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, Windows 7 64 bit
I'll buy stuff from either New Egg or Amazon, whichever is cheaper. I have Amazon Prime so I get free 2 day shipping on a lot of the stuff which sways me there when all other things are equal.
The stuff I'm looking at right now
Case - $134.99 Cooler Master HAF 932, Blue
I have the red version of this case for my current computer (I'll be using 2 computers). It barely fits in my desk (about a half inch vertical clearance without wheels on), so I'm definitely open to suggestions for other cases. Especially ones that might be a little quieter, and power buttons on the front are preferable. I do need to be able to fit the h100 with 4 fans for push/pull though.
Motherboard - $188.49 after shipping and promo, ASUS P67 Sabertooth
Plus assistant fan $6.98 Evercool 50mm
Processor - $324.99 i7 2600k
CPU cooling - $109.55 Corsair H100
2 additional $13.52 each Cooler Master Excalibur
Are they actually better than the stock fans? If not I have the 2 stock fans from another H100 that I could just use 4 stock
RAM - $94.99 16GB Corsair Vengeance DDR 1600
Video Card - $559.99 Sapphire Radeon 7970 3G
SSD - $295.99 Crucial M4 256GB
Power Supply - $155.98 after shipping. Corsair HX750 Silver
That puts me at 1871.99 shipped.
Any advice is greatly appreciated!
Cape Coral, Florida
1980x1020
