I need a new computer, price range of around $1000-1500. I'm gonna be saving up and will probably purchase everything in 2-3 months.
I've never built one from scratch before, so I have no knowledge of compatibility and all that stuff. I want to be sure everything I buy will definately work with one another, so that I can just put it all together and not wind up in a problem that I don't know how to fix or what caused it.
I basically only use it for watching movies, listening to music, downloading, and browsing the internet. I don't do any gaming but that's only because the computer I have wouldn't be able to handle it, so I might do some light gaming if I have a machine that is capable. I'm not going to be OC'ing or anything like that though.
My main concern is that I have no clue how to figure out what is compatible with what, and this is what I'm looking at so far...if you recognize any incompatibilities, or have better suggestions, if you see something that isn't needed, or I am missing a component or something please let me know:
Case: Antec P182 Gun Metal Black 0.8mm cold rolled steel ATX Mid Tower Computer Case
Motherboard: ASUS P5E LGA 775 Intel X38 ATX Intel Motherboard
Power Supply: CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply
Hard Drive: Seagate Barracuda 250GB
Processor: Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Processor
Memory: Kingston HyperX 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
Heatsink & Fan: ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
Graphics Card: EVGA 512-P3-N802-A1 GeForce 8800GT KO 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready SLI Supported Video Card
Sound Card: Creative Sound Blaster X-Fi XtremeGamer 7.1 Channels 24-bit 96KHz PCI Interface Sound Card
CD/DVD ROM: ASUS Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 14X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner with LightScribe
Thanks for your help fellas
