Building a computer....
collibr
I'm building a computer, new at it though. My budget is $1300-$1500 for a gaming computer. Just need a little help in the best products I can get for all the parts, cases, video cards, processors, mother boards, etc....Thanks
You could skim through the forums, then come up with a preliminary list, then run that by the forum; more likely to get a response; just an idea.
Otherwise, it just appears you want others to do ALL the work and fun for you.
Just my opinions:
AMD:
Foxconn C51XEM2AA- 8EKRS2H Socket AM2 NVIDIA nForce 590 SLI MCP ATX AMD Motherboard - Retail--184.99
http://www.newegg.com/Product/Product.asp?Item=N82E16813186098
AMD Athlon 64 X2 5200+ Windsor 2.6GHz 2 x 1MB L2 Cache Socket AM2 Processor - Retail --$289.00
http://www.newegg.com/Product/Product.asp?Item=N82E16819103759
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail--$236.00
http://www.newegg.com/Product/Product.asp?Item=N82E16820145590
eVGA 640-P2-N821-AR GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16 HDCP Video Card - Retail-$399.99
http://www.newegg.com/Product/Product.asp?Item=N82E16814130071
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM- $89.99
http://www.newegg.com/Product/Product.asp?Item=N82E16822148140
FSP Group (Fortron Source) FX700-GLN ATX12V/ EPS12V 700W Quad. SLi Power Supply - Retail --$139.99
http://www.newegg.com/Product/Product.asp?Item=N82E16817104015
Total=$1339.96 Before Shipping
__________________________________________________________________________
Intel:
ASUS Striker Extreme LGA 775 NVIDIA nForce 680i SLI ATX The Ultimate Gaming Motherboard - Retail -$419
http://www.newegg.com/Product/Product.asp?Item=N82E16813131074
Intel Core 2 Duo E6300 Conroe 1.86GHz 2M shared L2 Cache LGA 775 Processor Retail--$187.00
http://www.newegg.com/Product/Product.asp?Item=N82E16819115005
eVGA 640-P2-N821-AR GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16 HDCP Video Card - Retail--$399.99
TOTAL=$1468.99 Before Shipping
Both have onboard audio so I didn't include sound cards but if you wanted to get one id cut down on the memory or get a cheaper hard drive (was going to suggest a raptor but they were too expensive with everything else) ...and I didn't include any cases because thats purely preference. Again though this is just my opinion on what id buy with that kind of money...
Just my opinions:
AMD:
Intel:
I like his Intel setup.....the only change would be substitute that mobo for the cheaper evga 680i mobo http://www.newegg.com/Product/Product.asp?Item=N82E16813188009 and get yourself the e6600 (4megs cache will help for gaming :))
The Intel setup is good (with the Striker being replaced) except I'd suggest a Corsair HX620 PSU for that. You know, this probably should have been posted in General Hardware.
