Building a budget PC
It's past time for me to build a new PC. I've had my current one since 2003 I believe, and it still plays most games. But it is time to get a new computer to handle games better. I currently have an AMD Athlon 2800+ Barton, with 1.5gb Kingston HyperX ddr 400.
I am kind of an AMD !!!!!! but from all i've been seeing it looks like Pentium is the top bang for the buck at the moment. So I'm not against the Pentium, just haven't liked it in the past.
I was looking at an SLI motherboard, minimum 2gb of ram, 1 PCIe 7950GT Nvidia (or maybe an 1950XT ati? which is better for the price) unsure on which motherboard/CPU to get. I've debated between so many, which is why I've come here. I need help deciding.
Lets say I have 800-1000$ to use. I mainly buy from Newegg, I like them.
CYBERPOWERPC.com, these pc's rock (+ they are affordable)
this is probably the best link you'll ever get...
No... stay away from cyberpower...
Go with AVAdirect, same price, maybe slightly higher... but they have better customer service and better selection of components..
Do you need a case as well? Also SLI is not worth it. It's cheaper in the long run to just buy a better graphics card than two medium quality cards.
I have a 6300 with a DS3 and it works great. Everything is blazing fast, I really don't know why 6400's were even made :) . Well I know why, but the 6300 is just THAT fast. My rig cost me... 1,100 I think, but that's because I spent $250 on the case, Coolermaster 830 Stacker. I run all games on max settings :).
I do need a case, but that wasn't such a confusing part. I prefer to build the computers because that tends to be cheaper, plus that way I know what I'm getting and I don't have to deal with any tech support. But I'll take a look at some of those sites and see if it might be worthwhile.
With an $800 budget, here's what I'd build right now:
Intel Core 2 Duo E6300 - $187.00
GIGABYTE GA-965P-S3 Socket T (LGA 775) Intel P965 Express - $108.99
G.SKILL F2-6400CL5D-2GBNQ 2 x 1GB 240-Pin DDR2 800 RAM - $184.99
SAPPHIRE 100176L Radeon X1950PRO 256MB PCI-Express - $184.99
Seagate Barracuda 7200.9 160GB 7200RPM SATA 3.0Gb/s - $57.99
NEC Black DVD Burner - $29.99
XCLIO GOODPOWER 500W ATX 500W Power Supply - $51.99
Total: $804.94 without tax and shipping.
If you want to overclock, then ditch the E6300 and go for the E4300 - $179.00
The E4300 is slightly cheaper then the E6300 but it has a higher multiplier. If you know the basics of overclocking, a higher multiplier means it'll be easier to overclock. FYI though, there are going to be price drops for all Core 2 Duo CPUs in the next few months.
In addition, there have been a few rumors that nVidia may be releasing mid-range DX10 cards that'll drive down DX9 based cards. So it may be best to wait at least one more months to see if anything happens.
So if you need a new system now, then the system I spec'd out for ya is perfect. But if you're willing to wait, you may be able to build the same system for a lower price but with a faster graphics card.
Just food for thought.
Awesome, I just spent a while of my worktime building computers via AVAdirect, almost every computer was coming out to $1500+ , I finally got it down to $1000 but the motherboard was horrible and did not allow for future upgrades(2 pci slots, 1 pcie). I stopped looking at it much after that, and was almost prepared to ignore that fact. But your post I like a whole lot more.
Edit: is Express ATX anything I need to worry about? Will it fit in any ATX case?
how do the x1950s stack up i do see they have had a huge price drop...
i will be building a pc come pry late febuary early march so im browsing though all these posts about building pcs...
I'm normally all for Nvidia's but when I was looking into building mine I was checking out the 1900xt vs 7950GT.. bang for the buck I would say 1900xt, that's what I'll be getting.
Yah, danny's build is good. The price drops are scheduled for Q2'07, which is about 2 months away... so if you can wait a bit longer than that, then do so, otherwise, that build is what you should want. SLI is mainly for oversized monitors, 24"+ LCDs. The S3 is a great budget board, but if you have the budget for it, the DS3 can OC higher, I believe (and has solid caps, which helps with longevity).
Express ATX? huh? can you give me an example? If it said "Intel P965 Express ATX Intel Motherboard" ... that means the chipset is P965 Express, and the form factor is ATX, and the board pairs with intel chips.
Pentium? It's all about the Core 2 Duo, man.
I'm also in the process of building a new machine myself and I think Danny's build looks good as well. Is there anything you would do differently though say with $200 more ($1000 budget)? I am not a big pc gamer at all, so I was thinking about going with a cheaper video card and maybe upgrading the processor. Any suggestions...thanks!
In the future, start your own thread :p
Anyhow, since I'm already responding... If I had $200 more to spend, I'd upgrade the CPU to the E6400, upgrade the motherboard to the DS3, upgrade the HDD to the 320gb seagate 7200.10, upgrade the PSU to either an Enhance 5150 500W or Corsair 520W, add a Scythe Ninja or Tuniq Tower (or Zalman 9700), and since you have the budget, keep the x1950pro. If you really don't play ANY games, drop to a 7300GS or some other $30-$40 vidcard and bump that CPU up to the E6600.
What the hells wrong with them! there well cheap! and good pc's! I just got one it F****** amzing, quiet as a mouse and it runs EVERYGAME! I get 64FPS on FEAR with my 7900gs... (that I got with it). The whole system was only £460 (about $900, no monitor)
+ it looks sic (black case + blue leds x graphics power = sic games pc :p)
well I didn't no about that...
every company goes through a bad patch but when I bought my pc off cyberpowersystem.co.uk it was fine... ultra fast. UK RKS
