This will be mostly for Gaming and Web browsing.
My Budget is $500-$600 for the computer including tax and shipping I already own a monitor, mouse, and keyboard.
I live in Michigan.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
"Everything" is not a valid answer. Please list out all the parts you'll need.
I am a first time builder and I will need a CPU, Motherboard, Memory, Storage, GPU, Power Supply, Case and whatever else.
6) Will you be overclocking? No I will not be.
7) What is the max resolution of your monitor? What size is it? My monitor is an Asus VS278Q-P. 1920x1080 27in Led Monitor
8) When do you plan on building/buying the PC? Within a couple weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Usb 3.0, Crossfire Support, 500gb 7200rpm, etc.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? I have Windows 64bit
http://pcpartpicker.com/p/CW7x
Here is the build I put together earlier. I am wondering if this is a good budget gaming rig. Also, will I need any more fans than what the case already has? Need help on this build.
I live in Michigan.
