Hello dear Hard Forum Users!
I´d like to build a workstation for personal and professional use. My Budget is around 3100$.
1) Figure out your budget
As mentioned above, around 3100. Because of the fact, that i live in Germany, I am calculating high shipping and taxing costs.( Nevertheless, prices are way cheaper in the US than in Europe)
I do not need any software, except you guys think something required for properly running the workstation is required. I own an Windows 7 Ultimate License
2) Figure out which components you would need for your setup
I would probably build the workstation from scratch, because there is not much to salvage from an Imac, I guess
If it fits in the budget, I would also consider buying an 27" monitor.
3)Determine what the computer is going to be used for.
Mostly 3D stuff (simulation, animating) and Motion Graphics / Video Editing
I also would like to run a dual System (Windows/Linux)
On my weekends, i´d like to play some games (i enjoy BF3)
4) Figure out which features you want on your computer.
To be honest, my experience in this high cost and high value market is limited, so I went out and googled my way through the internet.
What i found and consider fit to my needs is :
A Motherboard that has
Firewire 800
USB (preferably 3.0)
Thunderbolt (seems hard to find and is optional)
PCI express
A dual socket
Space for up to 48 +GB Ram
As well as
SATA and SAS
An Nvidia Quadro or ATI Firepro
At least a TB HDD
An SSD
An Card reader
I am not sure about the cooling.
5) Determine whether or not you are planning on overclocking any of the components.
Probably not.
6) Determine how long you want your machine to last.
It should be suitable to work on for at least around 3 years.
7) DO SOME RESEARCH.
Well, I did. I might be able to get my hands on a used HPz800 with an ATI Firepro V7900 and
2xIntel Xeon X5570. If all else fails, this might be my option to buy for around 2300$ plus taxes and shipping.
I was also given the advice to buy an Intel D5400XS board + 2 x QX9775. I am not sure what to think about, because the board only seems to support DDR2 Ram.
Also I am not sure, if I should buy an CAD Card or an gaming card. (3D Stuff usually profits from drivers and the architecture of CAD cards, but the prices are quite extreme)
All in all, i hope you guys could give me some advice on which part to use to get the most for my money.
Feel free too propose a configuration of your liking!
I apologize in advance for my bad english, and do hope I have followed the forums rules correctly.
Kind regards
Alex
Firewire 800
PCI express
A dual socket
As well as
SATA and SAS
At least a TB HDD
An SSD
An Card reader
Probably not.
Kind regards
Alex
