EricFX1984
- May 21, 2010
I have decided to restructure my hardware... i need to build 3 PCs out of the hardware I have...
Box A: Mine, gaming and video encoding
Box B: Wife's Box, World Of warcraft and Starcraft II, it also doubles as our Home Theater PC and will be connected to a HD projector, as a result it would need to be rather quiet
Box C: My buddies box, this should be the slowest of all the machines, he will be providing his own hard drives and optical drives
CPU / Motherboard combos
Abit IP35 Pro / q8200 @ 3.15GHz
(it will not go higher and runs warm)
MSI 890GXM-G65 / Phenom II 965 Black Edition
(hits 3.8GHz on air, undervolted to only 1.325v, hits 4.0GHz with a little work, 4.4GHz with a chiller at 0c or less, board is on its way back from RMA
Gigabyte P55M-UD4 / Do not have a CPU for this, need to decide what I should put in it
RAM
Adata Gaming Series 4GB (2x2gb) DDR3 1600 CL9, hits a solid 2000MHz and will even drop to CL8 (so long as I have a fan on it, lol)
Geil DDR2 1066 4GB (2x2GB)
I will need another 4GB kit as 2 of the boards listed use DDR3
PSU
COOLER MASTER Silent Pro M700 RS-700
this go great reviews and has very low noise/ripple
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171037
Cooler Master eXtreme Power Duo 650 (not as very good PSU)
PC Power and Cooling Turbo Cool 510 SLI (does 650 peak)
Video Card
EVGA gtx260, overclocks like mad
HD4850 1gb, with Accelero s1 and a pair of 80mm fans, hits 825/1100 and is silent
HD4850 512MB, does not works quiet right, hits a solid 725 on core but the memory maxes out at 960(underclocked) any higher and the ram artifacts
as for the other stuff like cases and HSF, that is already decided
RAM
PSU
Video Card
