Building $2K SB Gaming Rig, Advice?
Dalius
1920x1080 max. settings gaming (Rift, WoW, Skyrim, Rage, Deus Ex 3, Half Life 3 [fingers crossed] later this year), programming (C++, C#, web), some graphic/video editing.
$2, 000 not including tax. No shipping as I am buying locally.
3) Where do you live?
Toronto, Ontario, Canada
CPU, Motherboard, GPU, RAM, Case, SSD + HDD, PSU, Blu Ray Reader, cooling solution
Monitor (BenQ E2420HD), Keyboard, Mouse, OS (Win 7 Pro x64)
6) Will you be overclocking?
Yes. Never have before, would like to start with this build
24", max. resolution is 1920x1080
Within the next week, just getting last minute advice now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
SATA3, USB3, and SLI/CrossFire would be nice nice. Most $200+ P67 motherboards seem to offer these features though.
Yes, I have a Win7 Pro x64 lisence from school I can use.
Been waiting to build a SB gaming rig for a few months now, but the wait is finally over! Will be gaming at 1920x1080, I want to be able to max everything out and not suffer framerate loss. Will be playing Rift, WoW, and Elder Scrolls V, RAGE, Deus Ex 3, Dead Island and others later this year. I'll also be using this PC for work (programming), as well as hobbyist-level video/audio editing.
I have a few parts already picked out, but I was looking for some suggestions for case, GPU, PSU, SSD, RAM and cooling solutions. Also, I have never overclocked before but it seems like a good way to increase longevity of my PC. Not sure what the best way to go about it is. Water cooling solutions like the H50 or H70 are nice because they requires no maintenance, and as long as they aren't too loud, they seem like an excellent purchase. But they are more expensive than aftermarket heatsinks, and I'm not totally sure if they would keep the CPU cooler... any suggestions would be appreciated!
Anyway, here are the parts I have chosen so far. Please critique this build and offer suggestions! Thanks a lot! <3
CPU: Intel Core i7 2600K
Mobo: Undecided - Been looking at the ASUS P8P67 Pro and Deluxe. The Deluxe has another LAN (which I don't need), USB3 front panel (which I May not need depending on case), and 16+2 power. Not sure what that means but from what i hear, it makes your overclock more stable. So I'm not sure which to go for really. Advice would be appreciated.
GPU: Undecided - I think I'd like to go with nVidia this time around, I have an ATI 4890 ATM (MSI) and I haven't had the best experience for it. Or it could just be my card. Either way, I've been thinking about a single 570, and possibly adding another one in a few months. Or a 580 now, and adding one in a few months. Or just get 2x 560s now. Not really sure, would love some advice.
SSD: OCZ Vertex3 120GB - Benchmarks make this (the 240GB, anyway) seem very nice. I hear OCZ support isn't great from various forums though. Looking for suggestions on this also.
HDD: WD Caviar Black 1TB
RAM: Undecided - No idea. RAM is the component I know the least about so I'd love for some suggestions! I hear 8GB is more than enough.
PSU: Undecided - No idea. Suggestions please! Would like a PSU that will allow me to potentially SLI down the road, if this build is not SLI'd to begin with.
OPT: Undecided - Not sure, but I know I'd like a blu ray reader + DVD writer combo. I have TV attached to my PC and nice speakers so it would be nice. My PS3's fan sounds like a vacuum these days and watching BR discs on it is unpleasant. Or maybe I should just stick with a cheap DVD writer... not too sure.
Case: Undecided - No idea. Currently have an Antec 900 and I'm not a fan of all the LED lights. I'd like something that would potentially fit 2 GPUs easily, but hopefully something not much larger than the 900. Quiet is nice, dust-catching features are nice. I care more about efficiency than looks in this department (as long as it isn't an eye-sore of course) Cooler Master HAF932 OR HAFX, especially the HAF X, have caught my eye personally.
Cooling: Undecided - From what I've read about, the Corsair H50 and Corsair H70 are pretty nice. Not sure if air or water is the way I want to go. Whatever is quiet and efficient
I do have a 'sample' build I made a spreadsheet of... I took a screenshot of it, here it is: http://i.imgur.com/EIgka.png
This sample build is based off of what I've seen other people use. I just made it to see what I could get in the price range but I am not sure if its an ideal configuration, so any advice would be appreciated!
2500K or 2600K
Asus P8P67 Pro
6950 unlocked to 6970 another later for SLI
OCZ Vertex 3 or Intel G3
Samsung F3 1TB or 2TB F4
cheapest G Skill Ripjaws 4GB or 8GB
Seasonic or Corsair 650-850 Modular
Asus Blu-ray reader and DVD drive
Keep the Antec 900
Cooler Master Hyper 212+
Done! :D
I'd recommend this MSI mobo:
$180 - MSI P67A-GD65 Intel P67 ATX Motherboard
GPU wise, I recommend getting a single GTX 570.
SSD wise, I'd avoid OCZ due to recent events with their current SSDs and their level of customer support.
HDD wise, avoid the WD 1TB Black drives as they are very overpriced. The WD 1TB Blue is a decent choice for the money.
RAM, go for the cheapest 8GB DDR3 1333 1.5V RAM from a reputable manufacturer you can find. Typically you can find G.Skill or Corsair fitting this.
Case, don't bother with the HAF X as it is overpriced, even at the pricematch price of $170. I recommend these cases:
$90 - Cooler Master CM690 II Advance ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$106 - Lian Li PC-7B Plus II ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$165 - Corsair Graphite Series 600T ATX Case
$160 - Silverstone RV02B-W ATX case
$220 - Corsair Obsidian Series 650D ATX Case
$220 - Cooler Master ATCS 840 RC-840-KKN1-GP Full Tower ATX Case
$230 - Silverstone FT02B ATX Case
$220 - Lian Li PC-A71F Black ATX Case
As for cooling, you basically want to avoid the Corsair H50 and H70 if you want quiet. The pump used with the H50 and H70 is a bit loud. I recommend this HSF:
$30 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
2500K or 2600K
Asus P8P67 Pro
Keep the Antec 900
Done! :D
Thanks dude! I think I would take the Pro over the Deluxe; Deluxe doesn't seem worth it to me. Not sure about the GPUs, I need to do some more research on AMD's GPUs. My 4890 hasn't given me the best experiences unfortunately. Is 850W enough for dual-SLI and OCing? Also, I hate my Antec 900! No way I can keep it :p Well it isn't that bad but cable management isn't that easy with it IMO, a bit cramped with a big GPU. (I Can't even imagine SLI in that case... lol)
Danny! I was hoping you'd reply, I've seen you post in other threads. May I ask why the MSI? My GPU is made by MSI and while it's okay, are mobos from ASUS or ASRock not better?
I'll take a look at other SSDs and HDDs. What is wrong with the HAF X, if I may ask? Some of the cases in your list are much more expensive than its PM'd price of $160. Is it just quality, or features?
Also, I've been recommended that cooling option on another site as well... I'll take a look at it. THanks for the reply!
Any more suggestions would be greatly appreciated! :D
The main reason for the MSI recommendation is that while the Asus mobos are very well featured, there seems to be a lot more than usual reports of issues with Asus' P67 motherboards. The MSI mobo I recommended has reviewed well and doesn't seem to have as many reports of issues as the Asus P67 Pro. I avoid recommending AsRock simply due to their warranty. Yes their P67 motherboard do have a two year warranty if you buy them before July but still not enough for me to recommend them over a MSI or Asus mobo outside of severe budget limitations.
Both features and quality.
I like my new 6850 1GB a lot better than my old 4870 1GB. The cooler design on it is much better and it OCs like a champ and stays cool. Honestly I don't even see a problem using a 650 from Seasonic or Corair. I have my i5 750 @ 3.8GHz and 6850 at 925MHz and 1150Mhz memory and haven't even got the fan to turn on on my Seasonic X-650. You want to be in the 50-60% range of the power supply for maximum efficiency anyways. I would go with the X-650 or X-750 personally or the HX offerings from Corsair. With modular you shouldn't have too much of an issue with cable management anyways. You could always get the Antec 300 as I think it is a bit bigger for cheaper and still amazing, but it sounds like you are into aesthetics. Good luck man, just do a little research and you will find some good gear.
