Hey, gang.
My father's primary PC recently died. I am evaluating the idea of buying a PC from Dell, barebones from TigerDirect, or other manufacturer vs. buying one. He is currently working off his old laptop (P3 w/ 512 MB of RAM), so this is high priority for him.
Looking at some of the barebone kits vs. the Dells out there, I wasn't sure if a Phenom x4 would be a better value over a C2D or C2Q in the <=$500 USD range. Again, I am completely open to buying a barebones or pre-built solution. I am out of my element on this one and am open to suggestions!
1) What will you be doing with this PC? Multitasking, all of these will be happening simultaneously: Stock trading, running IE, Access, Excel, VB, anti-virus scans, mutiple java apps *No gaming whatsoever*
2) What's your budget? Max of $500 USD, excluding tax and shipping.
3) Where do you live? Massachusetts
4) What exact parts do you need for that budget? Case, CPU, HSF, RAM, PSU, Hard Drive, DVD-ROM or RW.
5) If reusing any parts, what parts will you be reusing? I have a Gigabyte GA-MA74GM-S2 board, XFX 8500GT PCI-E video card, monitors and peripherals.
6) Will you be overclocking? No.
7) What size monitor do you have and/or plan to have? 19" monitors; 1440x990; additional monitor would be nice, but not needed.
8) When do you plan on building/buying the PC? ASAP
9) What features do you need in a motherboard? Gigabit LAN strongly preferred due to automatic backups and routine file transfers.
10) Do you already have a legit and reusable/transferable OS key/license? Yes, XP 32 bit only.
