As mentioned early I'm building a desktop for my father - he wants some heavy duty graphics capabilities. Any thoughts on the following build:
MOBO - http://www.newegg.com/Product/Product.aspx?Item=N82E16813130221 or if he goes AMD - http://www.newegg.com/Product/Product.aspx?Item=N82E16813138141
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202 or if he goes AMD - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103471
Memory - http://www.newegg.com/Product/Product.aspx?Item=N82E16820609408 or http://www.newegg.com/Product/Product.aspx?Item=N82E16820227388 (dont prefer this option b/c of MIR)
HDD - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136344 or http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
GPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16814150349
Ethernet - http://www.newegg.com/Product/Product.aspx?Item=N82E16833164125
(not sure if I need this or not, havent built in years)
Disk Drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
The Q&A:
Graphic Editing and Creation
Prefer to keep it around $1,000.
3) Where do you live?
North Florida
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything but the monitor
None
6) Will you be overclocking?
Probably not, but that depends on the performance of it stock.
Unsure (he didnt specify, and I forgot to ask)
As soon as I pick the parts and get them delivered.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Not sure, probably Firewire for any equipment he uses that may need it. Possibly RAID and Crossfire.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes.
Thanks for the input!
The Q&A:
North Florida
None
Yes.
