This will be both a work and play comp. New games, web browsing, folding and other distributed projects, MS SQL, Office 2010. There is the potential for minor web development and programming, but not something i would focus on for the build.
I'm a data miner/analyst by day and I tend to bring my work and work style home with me. This means I usually have 7+ apps running with multiple instances for many of them.
hopefully under $2000 all in
3) Where do you live?
Seattle, WA (Fry's and web)
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Mobo, CPU, RAM, Video Card, PSU, HDD, Case, Monitors, (cooling)
No reuse
6) Will you be overclocking?
No, but open to suggestions for improvements on stock cooling
triple-monitor setup, minimum 22"
In the next month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Crossfire or SLI would help support the 3-monitor setup, right?
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
No. I am planning on getting Win7 64-bit for System Builders.
The two core items I am hoping for with this build is the triple-monitor setup and the power to run multiple instances of a number of apps at once. Here are a few questions that may drive different parts of the conversation.
Here's a shot in the dark:
Thanks, guys!
No reuse
In the next month
1. What do you think about a 60-80GB SSD for OS/apps + 1TB for files? This should really push the launch speed for apps and OS, but I'm unsure of the cost:benefit for the SSD.
2. Would the applications I will primarily use (Office 2010, web browsers) take advantage of the i7's HT capability, or is clock speed more important (as for games)?
3. I would like to be able to expand my RAM beyond 6GB and have the ability to bump the processor up in a year or two. Would this require a higher-end mobo?
CPU/Mobo: Combo: i7 960 Bloomfield 3.2GHz & GIGABYTE GA-X58A-UD9 Just grabbed higher end b/c of X58 for future step-up
or Combo: i7 960 Bloomfield 3.2GHz & EVGA X58 132-GT-E768-KR
GPU:
RAM: G.Skill DDR3-1333 6GB(3x2gb) Preference between G.Skill and Kingston? Max MHz?
HDD: WD Black 1TB (FAEX) (also, see Q1 above)
PSU:
Case: Cooler Master HAF 932
Monitors: 3x Acer 23" Widescreen LCD
OS: Win7 Home Premium 64-bit OEM
GPU:
PSU:
Thanks, guys!
