I will mainly be gaming but photoshop and video editing will be done as well.
My budget is $200-300 monthly spread out over three months. so $600-900 in a three month period.
3) Where do you live?
I live in Reno,NV. I keep the computer in a cool room.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
I require a CPU AMD Phenom II X6 (or close to it), a videocard which is under 10.4 inches including the connectors, 8gb ram, power supply, two fans? or more, and a liquid coolant system for the cpu.
I will be reusing the motherboard: ASUS m4a78lt-m le, Case:Thermaltake V3 Black Edition (VL8000 series),500gb hd
6) Will you be overclocking?
No.
I own a LG E2360V-PN 23" LED. Sad fact: It cost half of what the computer cost.
When I get a final product list.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
N/A
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Windows 7 Home Premium 64bit
I bought a system from CyberPower and while I am happy with it, the video card is lacking. I'm not sure of the specs of the fans that are in the system as I can't find much on the system beyond a basic list of user friendly hardware. It is not completely necessary to replace the two fans but I do require that the system be kept cool. I also noticed two fans can go at the top of the case. That would be nice. The liquid coolant system I currently have on the AMD Athlon II X4 635 keeps it idling around 36-42c. Ideally, I would like a "better" liquid coolant put on the Phenom as I have read that CyberPower has rather cheap parts. I personally will not be building this as I suck at such things. I will be paying a local business hourly (and hopefully at my house) to put the parts in.
I can provide pictures/video of the inside of the case if I'm not clear enough about the fans or other things. My knowledge of hardware is extremely limited so bare with me please.
The specs on the current computer if you care to know:
Case: Thermaltake V3 Black Edition (VL8000 series) 18.60" x 7.50" x 16.90"
Motherboard: ASUS m4a78lt-m le
CPU: AMD Athlon II X4 635
Ram: DDR3 4gb (no idea of the brand)
Graphic Card: ATI Radeon HD 5400 w/ 1gb (no idea of brand)
Fans of some sort. 0.o
Some kind of liquid cooler for the CPU.
some brand 500gb hd
No.
N/A
some brand 500gb hd
