jazzman161
- Dec 6, 2004
Hey everyone. Question for all the pros out there. I've got my WHS build (self-build) running low on capacity and physical space for hard drives and was looking at picking up something like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816111051&cm_re=tr8m-_-16-111-051-_-Product
My question is, what would I need to build this on my own. I'd like to buy a bigger case than the one Sans Digital offers with more storage capacity instead of this one where I'm limited @ 8 bays.
As an FYI, I am using the ECS Black Series A785GM-M as the mobo in my WHS. It has 2 eSATA ports which I believe both support port multiplier. Ideally I would like to use both, down the road, with two separate DAS systems.
Thanks!
Thanks!
