Build or Buy (long post)
kcornia
So I've been doing some cursory research for a while, trying to decide whether I go with a Dell (18 months same as cash is nice but they're expensive and not sure of part quality), a cyberpower build (way better flexibility in parts selection, cheaper), or build my own (haven't done it before and I'm spending a considerable amount of money).
My budget is up to about 4k, but that has to include at least the Dell 24", which drops it to about 3300. I've priced the build at all three mentioned above, using newegg for the build parts. The details I came up with are below, and the conclusion I'm coming to is that cyberpower is probably the best bet because it is only $100-200 more than the build my own, and I get professional installation and 1 year warranty out of it (and I'm close to them so I can pick up and could drop off if there were issues). Dell is out because it comes up about >500 over the other two. The cyberpower is $3232, and this includes several small things like round cables and a temp gauge on the front. The newegg stuff is as close to the cyberpower parts as I could get, and comes in at around $2906 - about $100 in mail in rebates.
Am I missing something that changes the equation substantially? While I would probably enjoy the process of learning to build my own machine, I really don't mind not going through it, and have been happy with pre-built computers so far. I won't be tinkering with memory, overclocking my CPU or vid card, or anything like that.
Thanks in advance for any help! Details on parts is below:
CyberpowerPC stats ($3232)
• CAS: CoolerMaster Stacker 830 Tower 420W Case W/ Side-panel Window
• CASUPGRADE: 12in COLD CATHODE NEON LIGHT [+10] (BLUE COLOR)
• CPU: (Sckt775)Intel® Core™ 2 Duo E6600 CPU @ 2.4GHz 1066FSB 2x2MB L2 Cache EM64T [+134]
• CD: (Special Price) 18X DVD±R/±RW + CD-R/RW DRIVE DUAL LAYER (BLACK COLOR)
• CD2: LiteOn LH-20A1H 20X Double Layer DVD+-RW Super Allwrite + Lightscribe Technology [+41] (Black Color)
• CABLE: Round Cable Upgrade for Hard Drive, Optical Drive & Floppy Drive [+19]
• FLOPPY: NONE [-5]
• FLASHMEDIA: INTERNAL 12in1 Flash Media Reader/Writer [+10] (BLACK COLOR)
• FAN: CoolerMaster Liquid CPU Cooling Fan System Kit + 2 EXTRA CASE FANS
• HDD: Single Hard Drive (500GB SATA-II 3.0Gb/s 16MB Cache 7200RPM HDD [+107])
• KEYBOARD: PS2 MULTIMEDIA INTERNET CONTROL KEYBOARD (BLACK COLOR)
• MOUSE: Logitech Optical Wheel Mouse (BLACK COLOR)
• MOTHERBOARD: (Quad-Core Supports) Asus P5N-E nForce 650i SLI Chipset LGA775 FSB1333 DDR2 Mainboard [+23]
• MEMORY: (Req.DDR2 MainBoard)2GB (2x1GB) PC6400 DDR2/800 Dual Channel Memory [+180] (Corsair XMS2 Xtreme Memory w/ Heat Spreader [+45])
• NETWORK: ONBOARD 10/100 NETWORK CARD
• OS: Microsoft® Windows® XP Media Center 2005 Edition w/ Free Upgrade to Windows Vista™ Home Premium
• PRO_WIRING: Professional Wiring for All WIRINGs Inside The System Chasis with High Performance Thermal Compound on CPU [+19]
• POWERSUPPLY: Thermaltake ToughPower 850 Watt Power Supply - NVIDIA GTX 8800 Certified [+229]
• SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS 24/7 LIFE-TIME TECHNICAL SUPPORT
• SOUND: Creative Labs X-FI XtremeGamer 24-BIT PCI Sound Card [+89]
• SPEAKERS: Logitech (BLACK) X-540 70Watts 5.1 Configuration Speaker System [+21]
• TEMP: THERMAL TEMPERATURE LCD DISPLAY WITH 3X FAN CONTROLLER [+12] (BLACK COLOR)
• USB: Built-in USB 2.0 Ports
• VIDEO: NEW!!! NVIDIA GeForce 8800 GTX 768MB 16X PCI Express [+360] (EVGA Powered by NVIDIA [+5])
• VIDEO2: NEW!!! NVIDIA GeForce 8800 GTX 768MB 16X PCI Express [+642] (EVGA Powered by NVIDIA [+5])
Dell Specs ($3649)
• PROCESSOR Intel® Core™2 Duo Processor E6600 (4MB L2 Cache,2.4GHz,1066 FSB)
• OPERATING SYSTEM - Genuine Windows® XP Media Center 2005 Edition with re-installation CD
• UPGRADE TO WINDOWS VISTA Express Upgrade to Windows Vista Home Premium from XP Media Center Edition
• MEMORY - 2GB Dual Channel DDR2 SDRAM at 667MHz - 2 DIMMs
• HARD DRIVE - 500GB Serial ATA 3Gb/s Hard Drive (7200RPM) w/DataBurst Cache™
• OPTICAL DRIVE - Dual Drives: 48x Combo + 16x DVD+/-RW w/ dbl layer write capable
• VIDEO CARD - Dual 768MB NVIDIA GeForce 8800 GTX
• SOUND CARD - Sound Blaster® X-Fi™ XtremeMusic (D) Sound Card
• My Accessories
• SPEAKERS - Dell A525 30 Watt 2.1 Stereo Speakers with Subwoofer
• KEYBOARD - Dell USB Keyboard
• MOUSE - Dell Optical USB Mouse
• FLOPPY & MEDIA READER - 13 in 1 Media Card Reader
• ANTI-VIRUS & SECURITY Norton Internet Security™ 2006 Edition 15-months
• SYSTEM DETAILS 2.5MM aluminum thickness Chassis with front & back customizable LEDs
• SYSTEM DETAILS 7-slot, BTX design motherboard
• SYSTEM DETAILS 1 kilowatt Power Supply
• SYSTEM DETAILS Tower Six-heat pipe, Copper base Heat Sink with aluminum fans
• SYSTEM DETAILS Two 120mm x 38mm front fans
Newegg Equivalent ($2906 total)
COOLER MASTER Stacker 830 Evolution RC-830-KKN2-GP Black Aluminum ATX Full Tower Computer Case – 259.99
http://www.newegg.com/Product/Product.asp?Item=N82E16811119122
Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor – 316.00
http://www.newegg.com/Product/Product.asp?Item=N82E16819115003
SONY Black 16X DVD+R 8X DVD+RW 8X DVD+R DL 16X DVD-R 6X DVD-RW 5X DVD-RAM 16X DVD-ROM 48X CD-R 24X CD-RW 40X CD-ROM IDE DVD Burner – 45.49
http://www.newegg.com/Product/Product.asp?Item=N82E16827131039
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 8X DVD-R DL 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM IDE Burner with LightScribe Technology – 37.99
http://www.newegg.com/Product/Product.asp?Item=N82E16827106045
LINKSKEY LKA-CR15BW 52-in-1 USB 2.0 Internal 3.5" USB Card Reader – 13.99
http://www.newegg.com/Product/Product.asp?Item=N82E16820309001
COOLER MASTER RL-HUC-E8U1 Liquid Cooling System – 61.99
http://www.newegg.com/Product/Product.asp?Item=N82E16835103006
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive – 149.99
http://www.newegg.com/Product/Product.asp?Item=N82E16822136073
ASUS P5N-E SLI LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard – 134.99
http://www.newegg.com/Product/Product.asp?Item=N82E16813131142
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory – 352.00
http://www.newegg.com/Product/Product.asp?Item=N82E16820145033
Thermaltake Toughpower 850W W0131RU – NVIDIA QUAD-SLI APPROVED, FOUR +12V RAIL READY – 259.99
http://www.newegg.com/Product/Product.asp?Item=N82E16817153043
EVGA 768-P2-N831-AR GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 HDCP Video Card – 579.99 (X2-25.00 combo discount = $1135)
http://www.newegg.com/Product/Product.asp?item=N82E16814130072
Creative Sound Blaster X-Fi XtremeGamer 70SB073A00000 7.1 Channels 24-bit 96KHz PCI Interface Sound Card – 69.99
http://www.newegg.com/Product/Product.asp?Item=N82E16829102006
Logitech X-540 70 watts 5.1 Speaker – 88.99
http://www.newegg.com/Product/Product.asp?Item=N82E16836121006
Seems to come out several hundred dollars higher than the Cyberpower model, maybe because cyberpower has free liquid cooling special right now..
One term explains it: cyberpowerfucked
Try AVA. It's more expensive, but you will not be disapointed with them. Well worth the extra money you spend.
Be a man, Build it! lol. j/k, do whatever you want. pay someone else to build it, or pay yourself with the knowledge to build it.
So is the consensus that Cyberpower still sucks? Their ratings at resellerratings.com have gotten measurably better, is that not a reliable source? I'd really rather not build my own given the money I'm spending and my lack of experience, but if the savings are really that substantial then I'll suck it up.
Reading about how if I put too much thermal paste on the cpu I can eventually burn it up kinda worries me. I don't want to learn something like that the $4k way...
heh, grow some balls and build it! have confidence in yourself and take the time to learn. it really isn't that hard. and don't spend 4k on a system, lol... maybe 2k.
I doubt I'll be able to build a dual 8800GTX/C2D/24" monitor system for 2k, but we'll see what happens...
I meant spend 2k on the box itself, the monitor and other peripherals not included in that 2k budget. You already priced out the difference with Newegg. You're basically paying $300+ for someone else to have fun building your system for you.
If you have the time to put towards it, there is no reason not to build. It's such a good time, and the satisfaction of getting it all together and playing your games is unbelievable.
Other than maybe recommending to a friend, I don't think I'll ever purchase a prebuilt system.
Seriously, don't buy from Cyberpower. Even if you ultimately want to buy a prebuilt computer, don't buy it from Cyberpower. Like someone else has posted, you'll be cyberpowerfucked.
But I am going to recommend that you just buy parts for a $300 to $500 PC, build it and if it comes out great, then go for a $2000 build.
By building a cheap PC first, you get to make mistakes and learn from them. It's a cheap PC and any mistakes made on that means one less mistake on the more expensive PC.
And by building it yourself, you know you got great parts for a fact.
lol, $500 for a new system to learn on? eh, I'd rather use an old system, though the cpu socket stuff may be outdated, its better than spending $500 for a system you don't really need. Find an old system, take it apart, and put it back together again. Then read the guides available online. You can start with http://www.mechbgon.com/build/index.html
qft
That, or just have an experienced friend help you along.
3k and you're using a 650i? For that price, you should be getting a 680i.
I've said it before and I'll say it again.
Velocity Micro= Awesome and lower priced among the boutiques.
And PLEASE don't get the water cooling from Cyberpower. You might was well throw full beer bottles at your PC with it's side panel off.
Sorry for resurrecting this, but I have one last question around the vehement dislike of Cyberpower here. Is there somewhere I can go or threads I can read that outline the problems people have had with them?
At resellerratings.com they have a pretty darn solid record, both long term and recent (last 6 months), and they beat both AVA and VelocityMicro by quite a bit for a like configured system.
The more I look into it the less I'm willing to take on either the time or risk involved with building my own, so I'd like to have as much information as I can get on the various vendors out there.
Thanks in advance for any info!
cyberpowerfucked
And this article is a damn good review of Cyberpower's PCs:
http://consumer.hardocp.com/article.html?art=MTA0MCwsLGhjb25zdW1lcg==
Thanks Danny, I had found that in between checking back on this thread. Looks like Velocity Micro for me (HardOCP gold medal)..
Thanks for all the help.
