Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Gaming
$3500-3700 tax included
USA NY
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
"Everything" is not a valid answer. Please list out all the parts you'll need.
MB,CPU,PSU,RAM,GPU,sound card if needed gaming only,heat sink/fan,hdds pcie ssd for gaming? second drive for data,movies,music some games
none
6) Will you be overclocking?
probably not
30 inch gaming m monitor 2600x1600 not sure really
after the holidays
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
SLI,usb 3.0,SATA 6Gb
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit?allready have windows 7 home premium 64bit
