Sorry for another one of these but I'm seriously out of date with hardware.
1) What will you be doing with this PC? Gaming? Gaming
2) What's your budget? Are tax and shipping included? $1500 w/tax&ship
3) Where do you live? U.S., Minnesota
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific. req: CPU/Mobo, RAM, GPU - desired: PSU, case, HDDs, sound, optical
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. Enermax Noisetaker 600W, 1 HDD, optical drive and sound card
6) Will you be overclocking? no
7) What size monitor do you have or plan to have? 24" 19x12 native
8) When do you plan on building/buying the PC? 1-3 months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc. stability
[edit - snipping all the crap off]
Here's my starting point
- Gaming performance
- Stability
- Quiet
- GPU - 1Gb memory, minimum
Budget, non-SLI ~$1,350
Antec P182 $150
Intel Q9550 $320
Asus P5Q $120
2 mushkin XP ASCENT DDR2 800 (2x2Gb) -- 8GB total $180
GTX 280 $450
1Tb HDD $130
I *think* my existing PSU (600W) should handle the system (18A on each 12V rail).
How are the Asus boards performing as far as stability? Are Intel branded boards still considered rock solid?
- Stability
- Quiet
Antec P182 $150
Intel Q9550 $320
Asus P5Q $120
GTX 280 $450
1Tb HDD $130
