Build Help
Klynt
Would just like some feedback on my current build. I'm not planning to do SLI but I was wondering if it's worth my while to get DDR3 now, get DDR2/DDR3 on same board, or just stick with DDR2.
MB: ABIT IP35 Pro LGA 775 Intel P35 ATX
CPU: Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775
Video: EVGA 640-P2-N825-AR GeForce 8800GTS 640MB
Memory: Patriot eXtreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
PSU: CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W
Drive: Western Digital Caviar SE16 WD3200AAKS 320GB
Thanks!!
Clint
Most people would say it's not worth investing in DDR3 yet.
Especially considering the steep price of the modules and NON-dramatic performance advantages.
I think you should just stick with ddr2.
DDR3 is not worth it at this point. It's 3-4 times more expensive than DDR2 and it isn't that much faster. It's gonna be a while before DDR3 become really worth it.
Now I have some questions for you:
- What's your budget?
- What are you planning to do with this build?
- What size monitor do you have?
- Are you planning to overclock?
- What games are you planning to play?
Well I was kinda thinking towards the future with the DDR3 and saw that Gigabyte offered a board that allowed you to use up to 8 gigs of DDR2 and then if you so chose to upgrade to DDR3 it would allow 4 gigs of that. So ideally it would allow me to upgrade in the future when DDR3 starts to come into its own.
1. Budget right now is looking like $1,500 give or take $100.
2. Gaming mostly.
3. I forgot to link the monitor I was looking at so here it is: Acer AL2216Wbd Black 22" 5ms DVI Widescreen LCD Monitor with HDCP support 300 cd/m2 700:1
4. I'm not new to building but I am new to overclocking. I would like to try to a little bit with my next build.
5. WoW, Warhammer Online, Bioshock, etc...
Thanks!
Clint
The specs in your original post look solid. The 22 inch monitor will make full use of that GTS 640 meg... it's a good match. The one question I have is what do you plan to do besides gaming? If you do any image processing, video editing, HD viewing, software development, or any other particularly CPU intensive task, then you will be well served by the Quad. If not, then you might find that a dual core E6850 or an E6750 will perform better over the next year or so with the games you plan to play. Also keep in mind that dual cores OC to higher peaks than quad cores. You can get both an E6850 or E6750 in the 3.6-4ghz range with a good air cooler.
Mark.
Most of my time in WoW is spent AFK while I'm on the web, e-mailing, downloading torrents, etc. I just wanted a machine that's going to allow me to handle as much stuff as possible without getting bogged down.
I had not realized that the dual cores get a higher OC peak than the quad but I'm going to assume that this is marginal? Like I said I'm pretty new to the OC thing and I don't want to get too deep into it.
Thanks!
Clint
Well for your typical usage, I say a dual core would suit you better.
In my case, I do all those but I spend more than double the time working with image editing. So a quad may be ideal for my case.
Quad cores generate much more heat.. So your oc would be limited.
Once again I'm glad that I posted here before purchasing. I think you guys are right about the dual core. After looking it over it seems I'll get a lot more performance out of the dual core as opposed to the quad and I even found it for a couple bucks cheaper!
In the past I shopped around to get the best prices but this time I just went with Newegg to make shipping easier. The E6850 I found with Directron.com is going to keep me at budget but I've never dealt with them before. How are they?
Thanks!
Clint
Get the PSU from zipzoomfly instead, much cheaper there.
The B3 stepping of the Q6600 can reach around 3.3Ghz, while the G0 stepping can reach 3.6Ghz. The E6750/E6850 can reach 4Ghz. No, thats not a marginal difference... its substantial enough to make people think about getting a dual core now, and a quadcore later (in about a year or so, when the Yorkfield chips are out).
If you want the G0 stepping, ClubIT guarantees it. Newegg does not, I believe.
Thanks a ton guys!
I did end up going with the E6850 from ClubIT with the G0 stepping (<-- whatever that means) :D
Also, I figured I should have an account on zipzoomfly so I took your advice and bought the PSU there and saved about 25 bucks.
If all goes well you'll be hearing from me here shortly when I noob it up trying to overclock this thing! :)
Thanks again,
Clint
Good luck!
Well, try to get some info before you actually overclock it.
You don't want to blow up your new setup =)
