ZFS running 6-8 hard drives. (16-24 TB range) Plex media server transcoding [one - two max] 1080p streams.
Flexible
Canada
Motherboard, RAM, CPU
Case, Antec CP-850 PSU
6) Will you be overclocking?
No
N/A
Late March
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
ECC, 8+ SATA
Open source OS
Please help me - I've done the reading and I've decided on getting ECC for this build. Not looking for trouble on that point. I assume that puts me into AMD territory. So, which motherboard, CPU and RAM should I get?
Thx
Flexible
Canada
No
N/A
Late March
ECC, 8+ SATA
Open source OS
Thx
