Build Help: Sound Editing and writing computer.
Corban227
Hey Guys, Looking to build a computer very soon. It will primarily be used as a sound editing computer and composing computer.
Composing music and editing music. Computer needs to be able to handle a large amount of loaded tracks. Gaming on the side
2500 Absolute Max. If possible I would prefer to keep it down between 1500 and 2000
California. Near a Micro Center in Tustin
Build from scratch: Ram, Processor, HDD, SDD, Case, Optical Drive, Video Card and Sounds Card (SteinburgUR22) Monitor and OS
None
6) Will you be overclocking?
No
Looking for a 22-30 in Monitor
ASAP! Ready to buy tomorrow
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0.
No
Bout 1 hour, give or take
Not really worth going to MC then unless you drive an electric vehicle.
All right, here's a prelim build (without sound card or monitor):
$310 - Intel Core i7-4790 CPU
$88 - Gigabyte GA-H97M-D3H Intel H97M mATX Motherboard
$286 - 2 x Crucial BLS2CP8G3D1609DS1S00 Ballistix Sport 2 x 8GB DDR3 1600 RAM
$330 - Any GTX 970 you can find from Asus, eVGA, MSI, or Gigabyte.
$130 - Samsung 840 Evo Series 250GB SSD
$100 - Seagate Barracuda ST3000DM001 3TB 7200RPM SATA 6.0Gb/s Hard Drive
$18 - LG GH24NSB0B DVD Burner
$130 - Seasonic X650 Gold 650W Modular PSU
$71 - Noctua NH-D14 120mm and 140mm HSF
$92 - Windows 8.1 64bit
$1555 plus tax and shipping
Since this is for audio work, you'll more than likely want a quiet PC. Hence why I went higher-end on the PSU and HSF: Both are proven to be very very quiet components.
Choose your own case.. So I recommend the following low-noise cases:
$90 - Antec P280 ATX Case
$90 - Fractal Design Define R4 Black Pearl ATX Case
$120 - NZXT H440 White/Black ATX Case
$120 - NZXT H440 Red/Matte Black ATX Case
$130 - Corsair Obsidian Series 550D ATX Case
$240 - Silverstone FT02B-USB3.0 ATX Case
