Build Help Requested: Photo Editing / FPS Gaming
MONTYX5
I would like to build a new computer for my wife. She complains her current computer is not keeping up with photoshop and she needs more room for photo storage.
This is her current build:
Thermaltake Armor Series VA8000BWS Full Tower Case (Modified)
Enermax Galaxy 850 power supply
Asus P5W DH Deluxe ATX MB (V-Core Volt Mod)
Intel Core 2 Duo E6600 Processor 2.4 (Lapped) (overclocked to 3.3)
Geforce 8800 GTX
Crucial Ballistix DDR 6400 2GB
1-150 GB Raptor HD (Oper sys)
2-400 GB Western Digital Caviar (for data backup)
Kingwin KF Alumn Rack (removable hd rack)
DVD-Burn Plextor PX-755SA
Water Cooled:
BK-8800 GTX Full Block
D-tek Fusion CPU Cooler
EK North Bridge Water Block
Thermochill PA120.3 Radiator (3 Yate Loon Fans)
Laing D5 MCP655 Water Pump
Monitor: 32" Sharp Aquos LCD TV
Processor
Intel 05
Intel Core 2 Duo
6600 SL958 Malay
2.46 GHZ /4m/1066/86
L639F034
35637461
A1429
Core Voltage Spec
(.85-1.3525V)
*** Mainly photo editing; Photoshop CS3, Adobe Bridge, Adobe Lightroom, Photomatix, Gaming - fps type games, Photography storage, web browsing, & dvd burning.
*** Whatever it takes to build a solid and reliable pc that will last awhile, without going
bankrupt.
3) Where do you live?
*** USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
***Everything
5) If reusing any parts, what parts will you be reusing? Please be especially
specific about the power supply. List make and model.
*** I have a Enermax, Liberty Model: ELT620AWT if it will work.
6) Will you be overclocking?
***mildly+
*** I have a Sharp Aquos 32" Moitor LC-32GP1U
*** In about a month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
10) Do you already have a legit and reusable/transferable OS
key/license?
*** XP
Seriously looking to use the Intel Core I7 920?
Water cooling system, suggestions needed on cooling blocks for cpu, gpu, ect.,
along with a thermaltake armor case. The water cooling part can be determined after system has been defined.
Thanks
Before you buy a whole new system, I'd suggest trying this first: upgrade her to 8GB of RAM and turn 4GB of that into a RAMDisk using Superspeed Ramdisk trial. Then set the scratch disk to use the RAMdisk. That should boost performance nicely.
I built a RAID 0 box for a small image studio 2 weeks ago, a new startup here in Vegas that is making waves. They wanted a "demo" workstation to see what's possible for processing as they don't want to create a massive server-type situation in the office, but 3-4 workstations that are equal in performance and then just using simple file sharing as required. Very simple setup in terms of the network, but the workstation I built used 2 300GB Velociraptors (tried to sell 'em on SSD but the amount of data they're dealing with wouldn't be practical - again, a price-to-performance and ROI issue).
The hard part was getting them to spring for 16GB of RAM because of the cost, but a few weeks ago I saw that sale for 4 4GB sticks of RAM for about $450 and made a few phone calls and snagged a similar deal.
I set up Photoshop CS3 for 'em (their legit retail copy) on Vista Business x64. They started messing around with it, loading some rather large TIFF files in excess of 150MB a pop, several at a time, performing some basic scripted actions on 'em, blurs, filters, etc. Using the Velociraptors in RAID 0 meant very snappy and consistent performance, as well as having 16GB of RAM too. Also, it's a Q6600 based machine running rock solid at 3 GHz.
They were very pleased with the performance at that point, but I had a surprise for 'em. ;)
I asked if I could have 20 mins 'alone' with the workstation to "rewire it" as Tim Allen might say. That consisted of grabbing a trial version of SuperSpeed Software's RamDisk Plus 9 and installing it, doing the simple configuration, and then creating a 10GB RAMdisk and told Photoshop "Ok, you want a scratch disk? Here, try this on for size."
After I did some tests of my own using the same scripts they'd done earlier, boy... I tell ya. You haven't lived till you see 225MB TIFF files literally snap onscreen in the blink of an eye, multiple huge TIFFs with resolutions like 5000x5000 and even higher. That's what's possible with RAMdisks, because even Velociraptors in RAID 0 pumping out something like 280MB/s sustained pales to the close to 5GB a second in bandwidth of that RAMdisk.
I told 'em to come back in and rerun their test scripts.
Jaws hit the floor, folks. Well, not quite but figuratively speaking, at least.
They asked what I'd done, I told them I put the scratch disk in RAM where it should be if you have the RAM to make it happen, and they bought 4 licenses of RamDisk Plus 10 mins later, and I got a signed contract to construct 3 more workstations identical to that one top to bottom and also be their "geek" if any issues come up.
It was a very good week... ;)
Questions for suggested system:
1) Will this power supply work with the system. (Enermax, Liberty Model: ELT620AWT)
2) Storage capacity, as she is already approaching 1TB of data now, how many drives can I
add without adding a card.
3) She often works on files larger than 500mb in photoshop, what would be reccomended for
scratch disk on this system?
Other Questions:
1) She cringes at the thought of vista, so I was looking at Windows7, is it up to the task
yet?
Comments:
1) PC's are in unfinished basement and collect dust rapidly, thus the reason for liquid
cooling as it is easier to clean an external heat exchanger. Air cooling is not completely
ruled out at this point.
2) My personal P4 apparently has been damaged from dust bunnies on cpu cooler and requires
increased voltage to get it to run with intermittened freezes and restarts. Therefore, I was
looking to take her old system once the new system is up.
3) On the last build I had the time to research heavily, being a full time student, parent,
husband, etc., I just don't have the time to research everything on the market, but will do
the homework on the suggestions when time allows.
4) Was looking to overclock to the point of 24/7 stable.
Appreciate the help,
Monty
Dont change anything
That computer is powerful enough CPU-wise to handle that.
Max out the RAM and make a RAMdisk out of whatever you have available over 3GB.
Set that for the Scratch disk.
Serioulsy she will be shocked.
If you need more space for files just grab a 2TB and throw it in there for Storage.
Dont buy a Raptor.....waste of money IMO
Get an SSD instead.
Also dont RAID0 your SSDs your not editing live Raw HD video and dont need 400MB/s of sequential throughput. Access times are where the most benefit is and when you add RAID your access times increase.
1) The ELT620AWT only has 36A on the +12V rail (where your system draws most of its power). I'd strongly suggest a newer PSU thats 80+ certified, with at least 40A on the +12V rail. Check out the Corsair units, as well as the Antec Earthwatts and TruePower New units. BTW, the TP New 750W is on sale right now for $90 after coupon. While its overkill for your needs, that is a damn good price for a damn good PSU.
2) However many ports you have on board. The P5W DH Deluxe has 6x SATA ports, so you can have 6 SATA drives. If you go with the eVGA X58, that, too, has 6x SATA ports. Don't forget your optical drive(s) will take up ports, too, though.
3) As I stated earlier, and also mentioned by nitrobass, 4-5GB of RAM turned into RAMDisk would be the fastest thing for her Photoshop scratch disk.
1) Vista and 7 are both good enough for everyday use, but why even consider Vista? Just get 7 64-bit.
1) Get a case with fan filters. And if you don't want to, just get fan filters, lol. Oh, and check out the Corsair H50. :D
2) Great plan... go with the i7 shiro spec'd out for your wife. Then do the upgrades we mentioned for yourself, minus the RAMDisk if you don't use PS. However, with the 12GB of RAM on the i7 system, turn at least half of that into a RAMDisk for her scratchdisk. ;)
3) Or just trust us blindly. :p
4) Easy with a D0 stepping. Keep voltage as low as possible, and dont let temps go above 80°C load on the i7, IIRC.
EDIT: If you do get a single SSD, get an Intel X25-M. The Indilinx controlled SSDs have very poor small random write speeds compared to the X25-M and would need a 2nd SSD in RAID0 to make up for that deficiency and perform similarly to the X25-M. Though, compared to a mechanical disk, the small random write speed of Indilinx drives is fantastic, lol.
EDIT: If you do get a single SSD, get an Intel X25-M. The Indilinx controlled SSDs have very poor small random write speeds and need a 2nd SSD in RAID0 to make up for that deficiency.
Could not disagree more with this.
First off saying that Indilix drives have very poor 4k writes is extremely misleading.
They have fantastic 4k random writes.
They are just not as good as the Intels.......for a while.
Dont beleive me? Go bench any HDD on 4k writes and then tell me your thoughts;)
Im sure you will be shocked.
Right out of the box Intel has faster 4k random writes.
But steady-state performance is what matters most. Currently TRIM does not work as intended on the G2's and not at all on the G1's
So after you have "used" both SSDs the OCZ will be better
First off saying that Indilix drives have very poor 4k writes is extremely misleading. ...
Ugh, fine, fixed. :p Still, a single Vertex drive underwhelmed me, and I attributed that to its slower small random write speed. Getting two in RAID0 is when it noticeably pulls away from the Caviar Blacks -- in desktop usage. In a netbook/laptop... wow, Intel or Indilinx based doesn't really matter since either will blow away the performance of a 2.5" laptop drive.
For me, going from a single caviar black to a single Vertex was like going from a regular 'cuda.10 to a Raptor.g2... not much difference to warrant the price premium.
Ok, I've done some research following your suggestions and this is what I've come up with. She had some concerns over operating/apps drive space, so I've increased that. Let me know what you think about the build, as I would like to place order soon.
CPU
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor: Retail-$199.99@Micro-center
CPU Cooler
Should I stay stock – or what other heat sinks will work with this board combination?
Motherboard
EVGA 141-BL-E757-TR LGA 1366 Intel X58 ATX X58 SLI LE Intel Motherboard – Retail - $219.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188049
Memory
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL – Retail - $85.99 x 3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277&cm_re=ripjaws-_-20-231-277-_-Product
Video Card
ASUS EAH5870/G/2DIS/1GD5/A Radeon HD 5870 (Cypress XT) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card w/ATI Eyefinity – Retail - $379.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121346&cm_re=5870-_-14-121-346-_-Product
Hard Drives
Vertex 2.5" 60GB SATA II Solid State Drive (OCZSSD21VTX60G) $209.99/179.99EA. after rebate-Micro-center
2 in raid0 for os & apps
Data:
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drives – OEM - $94.99 Newegg
Optical device
For making backups of movies, 1 or 2 DVD R/W needed for this.
Any suggestions on this?
Power supply:
Suggested min. requirements: 80+ certified, 40A+
I also added: Active PFC, Modular
ENERMAX REVOLUTION85+ ERV850EWT 850W ATX12V / EPS12V SLI Ready CrossFire Certified 80 PLUS SILVER Certified Compatible w/Core i7 Modular Active PFC Power Supply – Retail 179.99 after rebate -Newegg
Cases:
Antec Twelve Hundred ATX Gaming Case-139.99@Micro-center
Concerns:
Possible problems with case and length of video card and choices for cpu cooler, can anyone comment on this?
Can you see any other conflicts in components with this build?
Thanks In Advance,
Monty
Ixnay on the Arkday Nightkay.
If you're pursuing an air-cooled CPU cooler, either get one with a four-pipe HDT (heatpipe direct touch) design, like the Xigmatek HDT-S1284EE, or get one with a "solid base," like the Cogage TRUE Spirit. (The TRUE Spirit has received many positive reviews, including here at the [H].)
If your gonna do an x58 build then you need triple channel memory.
If not just get a p55 board and use the dual channel memory and save some money.
lol... nitrobass may you didn't notice that he has listed 3 x 4 GB kits. Which is 2 pieces of memory by 3 and that equal to 6.
Ok, I went and compared cases at Micro, decided on the Antech 1200. I liked the built in removable filters and fan control. Picked up the two OCZ drives, as well as the cpu. I have decided on the Cocage cpu cooler since it has done well in the testing reviews and less likely to cause interference problems.
Went to order the rest of the parts from egg, but they are now out of the EVGA mb:(. Looking at the next level EVGA board “E758” (+$30), besides possibly needing the extra sata ports in the future, are the controller cooling upgrades of any benefit? Is there even an issue with controller heat on these boards or should I just wait for the E757 boards to become available? I am already waiting for the gpu to come back in stock and the Win7 release anyways. While I could work around the win7 thing, it has given me a reason for my eager wife to stop riding me like a stolen dirt bike about the completion time of her new toy;).
Also, any suggestions for a bay mounted multi media card reader or are the all about the same?
Personally not a fan of the Antec 1200 on account of how cramped it is compared to cheaper or equally priced cases. But if you like it, keep it.
There really isn't a cooling issue with the southbridge/storage controllers at all. If you can wait for the E757, then wait. If not, the E758 wouldn't be a bad buy per se.
Bay mounted media card readers are all about the same to me.
1. Buy an SSD drive to host your photoshop/image editing program.
2. Increase your RAM to the max.
That should be a good start and like will cost you under $400 to do.
My intentions are to:
Purchaced-two 60GB SSD's and will be running in raid0 (os, apps & a few games).
Install WD for data storage
Intend on installing all 12GB of ram (the ones suggested)
Bring the system to life (tweak)
Let her get the feel with large files in photoshop (1 or 2 good days).
Then bring on the ramdisk and see how it improves on this some more and tweak its size.
Is this what you are suggesting?
Does this sound about right for a backup drive setup for this system?
2x60GB(raid0)os/apps-----120GB
1TB data---------------------------1TB
1.5TB backup-----------------1.5TB
Thinking of using the Western Digital Caviar Green 1.5TB Hard Drive, is this a good choice?
What could I use the spare space for in the backup drive(unbacked up)?
You may also want to look into an external drive for backup. You can leave it off most of the time, and its somewhat portable, so if there's an emergency you can just grab it and go.
This is a great suggestion that I have taken up. I will be going with a Antec MX-1. Thanks for the suggestion.
np. don't forget to let us know how the setup goes and plz post some pics! ;)
