Moslty gaming
My budget isnt set , but would love the best ''money for quality'' i could get
Canada
Cpu , Ram , mobo and maybe PSu , see below
hard drives ( 2 Ssd( 1x128gb and 1x256 gb and 2x 2tb harddrive)
Case Corsair 500R (new)
cpu cooler Corsair H60 (new)
want to reuse my P/S wich is a Enermax Liberty 620w , but i heard they are bad. Mine been solid since i have it. I could change it , but if its not needed , ill rather keep it.
Vid card Gtx 680 msi twin frozr
6) Will you be overclocking?
i do not wish to overclock.
1080p 27 inch
July
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video
Usb 3.0
Moslty gaming
Canada
1080p 27 inch
July
Usb 3.0
