Build Help for Cyber Monday
Brose
Hello, I'm looking to upgrade my PC I built back in 2008. First off, I appreciate the help that you guys put forth for people like myself. I always like to compare options so a couple recommendations with reasoning would be greatly appreciated.
Here are my current specs:
Motherboard - Asus P5Q PRo
Processor - Intel Core 2 Quad Q6600 2.4 GHz
RAM - 2.00 GB
Video Card - ATI Radeon HD 4800 series
Power Supply - Corsair TX750w
Case - Cooler Master CM690
Hard Drives - Western Digital WD1200JB 00GVC0
Western Digital WD6400AAKS 00A7B0
I mostly play video games such as Diablo 3, Hearthstone and possibly Wildstar or Elder Scrolls Online when they come out. I also tend to watch livestreams on Twitch. The problem is that I can only really have one stream open with it on the lowest settings. I would prefer the ability to have 2-3 streams open with higher settings.
I don't necessarily have a budget. I don't need overkill, but more of a most bang for my buck type of deal. With that said, I would like to keep it below $800 before tax and shipping if that is even possible. But, it's not a hard rule.
Maryland
I don't want to have to upgrade if I don't have to. With my limited knowledge I would say CPU/Mobo, RAM and Video Card are what need upgrading the most. However, I am open to suggestions if something sticks out.
Similar to question 4. I don't want to reuse anything that wouldn't be considered a "necessity" to upgrade. How important is/are the hard drive(s)?
6) Will you be overclocking?
No
I have a 22" Dell U2412m and have been using it at 1920 x 1200 at 60 Hz
Looking at upgrading some with Cyber Monday.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Unfortunately, I don't know what most of this is to even know if I need it. So probably nothing special.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, I have a useable Windows 7 64bit
If you need more information, just let me know. Thanks for your help!
$185 - Intel Core i5-4430 CPU
$90 - MSI Z87-G41 PC MATE Intel Z87 ATX Motherboard
$60 - Crucial Ballistix BLS8G3D1609ES2LX0 8GB DDR3 1600 RAM
$145 - SAPPHIRE 100354OC-2L HD 7870 Ghz Edition 2GB PCI-E Video Card
$90 - Samsung 840 Evo 120GB SSD
Total: $570 shipped
Yes you can reuse your case and PSU. As for the hard drives, reuse them for the extra storage. However, reinstall Windows onto the SSD. The SSD will make a massive difference in the responsiveness of the system. So just keep the OS and critically needed or heavily used programs/games and the hard drives for everything else and you'll be fine. However I would not recommend installing any programs or games onto that WD 120GB drive as that drive is extremely slow by today's standards.
As for the video card, yes the HD 7870Ghz is big step-up over the HD 4850. However, I would highly recommend grabbing the HD 7950 (if it ever shows up under $250), the HD 7970 (if it ever shows up under $290) or the R9 280X (if it ever shows up around $300) if you plan on playing more higher-end games.
Thanks! I was looking at an Intel Core i5 4570. Would that be much different from the 4430? Also, would it be a good idea to grab two sticks of the 8gb RAM? Finally, I think I will try to go with the HD 7950 as well.
I had an idea on things from browsing the website, but I just don't know what to expect since this is mostly Greek to me. Hopefully, Cyber Monday helps me out with some of these upgrades!
Not really no.
If you can afford it and if doesn't cut into the budget for other parts, yes. Though you're better off getting a larger SSD first than 16GB of RAM:
$160 - Samsung 840 Evo Series 250GB SSD
Good luck.
