Build help for a friend 2k!
hey guys i need help with a build for a friend. His budget is around 2000.
He mostly place WoW on a 24" monitor but is going to start playing more FPS.
Let me know what you guys think.
Well, here's my first question to you as you did not provide quite enough information for specific help.
What hardware will he be recycling (re-using)? Also, will he keep his 24" monitor? Does he want new keyboard, mouse, and/or speakers? One thing that I think is simple is choice of video card -- go with an 8800GT 512MB. Then once nVidia has got their new flagship GPU out, trade up or sell and upgrade.
Yeah some more info would help:
- What parts does he need for that $2000 budget? And please be as specific as possible
- Will he be overclocking?
- Will he need a new OS?
- What features does he need in mobo? Firewire, RAID, more than 4 SATA ports, etc
- How often does he upgrade?
Sorry for being so vague..
I just built this computer below.
Q6600 + Thermalright TRUE.
IP35-Pro
EVGA 8800GT
2GB of Gskill DDR2-800
500gb Samsung HD
Corsair 620HX
CM 690
My real question is if he wants to spend more than I did where is the best
places to put that cash?
He needs everything except Monitor( he uses a 24"), Keyboard, mouse and speakers. I don't think he "needs" a OS as he has XP but I think he wants to get Vista for the DX10 games.He told me he wasn't planing on overclocking but I will convince him to squeeze a conservative OC out of whatever he gets. I think his normal upgrade is right around the 2 year mark, right now he has a older Dell XPS. In a Mobo he doesn't need anything special also doesn't need much storage space either.
Thanks,
Brandon
Hm... with a 24" monitor, I'd bump it up to an nForce 680i SLI (or 680i LT SLI) board from eVGA -- if you can find one -- and throw in another 8800GT. Then I'd go for a 2x2GB DDR2-800 ram kit for under $115.
$160 - eVGA 122-CK-NF67-T1 LGA 775 NVIDIA nForce 680i LT SLI ($30 MIR)
$110 - G.Skill 4GB(2x2GB) DDR2-800 F2-6400CL5D-4GBPQ
The NF68-A1 is OOS everywhere. He may want to wait for the new nForce chipset and the Yorkfields, which are coming out early next year (jan).
680i boards are you best option if you want SLI. They're not the greatest boards, especially when OC'ing a quadcore. If you just want a modest OC on a Q6600, don't plan on upgrading to a yorkfield, and want SLI, then the 680i SLI LT is your best choice.
SLI is good for high resolution 3D rendering. However, on a 24" LCD, you can still get away with a single vidcard (GTX or Ultra). The 8800GT is nearly as good as the GTX, but about half the cost -- so stick with it. Go with an eVGA and hopefully he can step up to either the GTS or GTX replacement, whichever comes out first.
+1 go with this. with a 24" monitor while you can stick with a single video card it's best to go with SLI cuz at high resolutions you're gonna need the power.
