Build for WoW and Blu-ray's
Eiolon
World of Warcraft, Blu-ray movie watching simultaneously
Preferably around $800, hard cap at $1000 after tax/shipping.
AZ
Case, motherboard, CPU, memory, power supply, video card, hard drive, Blu-ray drive
Monitors
6) Will you be overclocking?
No
Two 1920x1200 monitors
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0
Win 7 64-bit
Build is for watching movies while playing WoW (2 separate monitors).
I'd like to try and squeeze a SSD and a 1TB hard drive in there if budget allows.
Thinking about this case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216
Here's a build:
$285 - Intel Core i5-3450 CPU + Biostar TZ77B Intel Z77 ATX Motherboard
$39 - G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
$250 - PowerColor AX7850 2GBD5-2DH Radeon HD 7850 GHz Edition 2GB PCI-E Video Card
$125 - Crucial M4 CT128M4SSD2 2.5" 128GB SSD
$90 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$63 - Asus Blu-ray drive
$63 - Antec NEO ECO 520C 520W PSU
$76 - Corsair Carbide Series 300R ATX Case
Total: $991 shipped.
Got the SSD and a fast 1TB drive. BTW that 1TB drive is on sale right now so I'd recommend buying that part ASAP. The 300R case is cheaper than the RC-690 but of slightly better quality, more up-to-date features, and slightly better cooling.
I recently bought a Pioneer BDR-206 (2206 which includes Cyberlink software). The included Powerdvd 10 sucked. If I had known I would have gone with an OEM drive. You can setup XBMC to play Blu ray movies. You don't have to buy overpriced buggy software.
My main usage was going to be burning, not watching movies, but having decent software would have been nice. I haven't had reason to use PowerDVD in years and it brings back nothing but bad memories.
I use TotalMedia 5. Pretty happy with it and its integration with Media Center. I used it with my HD-DVD/Blu-Ray combo drive until it died and LG won't replace it because on serial is on the label.
Thanks!
Is there a comparable video card in nVidia flavor? I only ask because I am using an ATI card right now and the drivers are very bad for me on WoW currently. I had to revert to the drivers that came with the card over a year ago.
Thanks!
Probably the GTX 560 TI 448 Core. But it only has 1.2GB of VRAM and cost $50 more. The only decent Nvidia card with 2GB of RAM is the $400 GTX 670.
For nVidia solutions $200-300 you will want to look for GTX 470, 560 Ti, 560 TI 448 and GTX 570. If you are willing to do refurb this $244 MSI GeForce Twin Frozr II OC GTX 570 with a one year warranty isn't a bad option.
Getting ready to order today. I forgot to ask, what is the preferred thermal paste for CPU's these days? Last I used was Arctic Silver 5 but that was 4 years ago.
Whats the final build list? Oh and grab MX-4 for the thermal paste
