Mainly for Coding (Cuda - GPGPU & C++ ) and Video editing (1080p)
Around £800, No tax and shipping not inculded
3) Where do you live?
UK
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Pioneer DVD-RW
6) Will you be overclocking?
NO
I have 2x dell 20" 1680x1050 (dvi)
Building in the next month or so
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Raid, Esata, USB3 (possibly, might just be to expensive)
10) Do you already have a legit and reusable/transferable OS key/license?
Win 7 Pro 64bit
I'm not sure about the above, I have heard alot about EVGA M'Boards here. with the graphics card i have No idea at all... same fo psu
Thanks
Satpal
UK
- CPU - i7 / i5 Is there a massive diff in processing power?,
- CPU Cooler - Noctua NH-U12P SE cooler
- Motherboard - ASUS P6T SE iX58 Socket 1366 8 Channel Audio ATX Motherboard
- Ram - OCZ 6GB (3x2GB) DDR3 1333MHz/PC3-10666 Platinum XTC Triple Channel Memory Kit CL7 1.65V,
- GFX Card - Inno3D GTS250 Overclock Edition 512MB DDR3 Dual DVI HDTV Out x2 or a single Radeon HD 5850,
- HDD (Kingston 40gb ssd & WD Black x2 (640/750gb), stripe),
- Case - The Cavalier case currently in use by the other half, has a old dfi lanparty 939 setup in it, so i was thinking that i could by a cheap case for that setup and reuse the case, with a decent power supply? Would like to keep it quite.
- PSU - Coolermaster Silent Pro 500W Modular PSU
Pioneer DVD-RW
NO
Win 7 Pro 64bit
Thanks
Satpal
