Build for Sister
XSNiper
My sisters computer recently crapped out. Now I'm set to build her a new one. She has a budget of $700 and $20-30 for speakers. She mainly watches videos (ie. college classes) and listens to music. What would be the best options
While the parts you chose were decent, a few of them were outdated, like the Socket 939 stuff and some of them were a bit more expensive than necessary like the power supplies.
So basically your parts weren't the best bang for the buck. Here's what I'll buy with a $700 budget for your sister:
COOLER MASTER Centurion 5 CAC-T05-UW ATX Case - $49.99
Intel Core 2 Duo E4300 CPU - $177.99
BIOSTAR TForce965PT LGA 775 Intel P965 Express ATX Intel Motherboard - $104.99
Kingston KVR667D2K2/2GR2GB (2 x 1GB) 240-Pin DDR2 667 - $163.99
BIOSTAR V7302GL16 7300GS PCI-E Video Card - $54.99
Seagate 7200.10 320GB SATA 3.0Gb/s Hard Drive
XClio 450BL 450W Power Supply
$679.93 + Tax and Shipping
Besides being just under your budget, the build includes a Core 2 Duo CPU, the fastest and best performing CPUs out right now, 2GB of Ram to help with multitasking, and a much much larger 320GB hard drive. Since you sister isn't a gamer, a 7300GS seems right for her. This build should last her for quite awhile.
Oh as an added plus, most of the hardware carry at least a 3 year warranty. So should this system fail, there won't be any need to spend money on new parts.
change the centurion 5 to a 534, and that seems good enoguh for jsut watching videos/basic work.
Don't you think thats a little overkill for her Danny? She only wants to watch college classes online and listen to music here and there....She doesn't need one that better than mine, she needs one thats better than hers.
Then give her yours and take the new one. Danny's build is the best performance for the $700. That system should last a while, lol. If you dont need 320gb, drop down to the 250GB seagate.10 or 160gb wd1600js. I agree with filthysanchez on the 534 case. If you dont want to get her a nice case and PSU, you can get the FAR stuff from frys.com. Here's a build I posted earlier for someone else:
$163 - Intel Core 2 Duo E4300 Allendale 1.8GHz 2MB L2 Cache
$119 - Gigabyte GA-965P-S3 Socket T (LGA 775) Intel P965 Express
$155 - Corsair XMS2 2GB (2x1GB) DDR2-675 TWIN2X2048-5400c4 ($185 - $30MIR)
$70 - eVGA 256-P2-N443-LX GeForce 7300GT 256MB
$53 - Western Digital Caviar SE WD1600JS 160GB 7200RPM SATA300 8MB Cache
$31 - Lite-On 16X DVD±R DVD Burner Black SATA SH-16A7S-05
$10 - Ultra V Series 500W Power Supply ($40 - $40MIR + ~$10 ground shipping)
$0 - Ultra Wizard Black Mid Tower Case ($40 - $40MIR + free shipping)
$601 + tax and shipping (after rebates)
Ok, I understand its the best performance for $700. She doesn't need the best performance. She needs a cheap computer. It doesn't have to fill out $700 thats just the limit. I'd hate to get her something she won't take advantage of. I don't understand why I'm being forced to go dual core and get a massive amount of RAM. Anybody else have a suggestion that would be good for an everyday computer. (I.e surfing the net, listening to music, word processing)
Yes I put one together real quick and the price came out pretty decent once I lowered the RAM and HDD and different brands. Please critique it still as far as brands are concerned. I'm not really sure if Corsair did good with 240-pins and I don't know if the ASUS mobo is really reliable..
I do want the best bang for "my" buck. I just don't need all the bang that has been suggested. Its wasteful in my opinion. It's like buying a 8800GTX for someone who doesn't game...
Seems like you don't want her to get a better computer than yours. She WILL take advantage of dual core one way or another, even if its just web surfing, music, and videos. She might want to burn stuff one day or do other things so that leaves room for future-proofing(sp?) and 1GB of ram is sufficient for whatever task you put her at. I agree with going CD2 over AMD at the moment when building a new system. As a consumer, you should always shoot for the moon, especially when its within your grasp. Don't settle for less when you can get something of equal cost that does so much more.
The 8800GTX analogy doesn't fit for everything. Giving someone a dual core proc gives them the option of doing more than one thing at once which can accomplish a lot more than a 8800GTX -ever- will. So yes, giving her a 8800GTX would be stupid but giving her a dual core proc would just be reasonable.
She really is looking to get a smaller case now. Which means I would have to go MicroATX.
I have picked out a mobo here and would like to know if it would be good.
http://www.newegg.com/Product/Product.asp?Item=N82E16813131046
I'm not worried about her getting a better computer then mine, because she isn't with these suggestions. I want something that fits her needs. She won't be doing more and more web-surfing and word processing in the future so that is unrelated.
Thats a good one because it has onboard video which will save you a bit of money for something else. A lot of the newer onboard videos support up to 1650x1050 (or higher...dunno) which is a nice touch. If that intel one does? I'm not sure.
So your build is $28 cheaper than the one I posted. Though, the one I posted has a better hdd (sata instead of ide), double the ram, a better mobo, a case included in the price, a more powerful PSU, and an optical drive included in the price. Wow... thats alot for only $28, lol.
Anyhow, I'd stick to the G965 Express chipset for onboard video and microATX. This one looks affordable:
$95 - Msi G965M-F LGA 775 Intel G965 Express Micro ATX
If she goes with vista, she'll need 2gb. The XClio 500W is a better PSU for your money, since its the same price as the FSP AX### model. Here, save $10 on the ram:
$79 - pqi POWER Series 1GB (2x512MB) DDR2-533 MAB41GUOE-X2
If you really want to save money and get the cheapest computer possible, go with a dell. Pre-built is the cheapest you can get aside from used.
QFT. I don't get why people refuse to listen to sound advice. Your choices were excellent.
there's only 1 IDE channel on that board, it's going to cut speeds down quite abit if you stick an IDE dvd/cd drive in there too.
More like $128. I don't trust rebates at all. I have never had one work, and I'll never deal with them. She also wants to use newegg. I told her to get the SATA version of the HDD.
You can watch videos or listen to music on any kind of computer. If you get her $20 speakers then any onboard soundcard can handle them. To watch videos just get her a DVD drive. Do you WANT to spend $700 or do you want to go as cheap as you can go?
For what she wants to do, you can buy her a $300 dell online.
Listen to music with $20 speakers, any sound card can handle that. Play movies, any DVD drive can handle that. Word processing, a Pentium 4 can load it in like 10 seconds, and from then on it doesn't matter.
Just to give you a comparison, my dad used to play DVD's on a 21" and 5.1 sound on a Windows 98 HP computer. Pentium 3 :). He also used Corel Draw 10, Photoshop, and many other programs on it. Only reason he switched is because it finally DIED, LOL.
I'm sorry to hear that the rebate gods hate you. I've recommended that case and PSU to numerous people I know, personally, and not one of them has not received their rebate(s). I, myself, have actually oreder the PSU twice, and have gotten both rebates back rather quickly. Nonetheless, your sister's cheapest solution would have been a Dell.
