I'm looking to build one or more PCs for calculations in a physics lab (mostly large fast Fourier transforms). The task is very computationally demanding, but does not require much RAM (~1GB) or storage (2TB). I have benchmarked GPUs previously and found them to be by far the most cost effective way of doing this efficiently. However, extrapolating from initial tests, I would still require around 12 relatively cutting edge GPUs (nVidia GTX 570 seems ideal in terms of cost to performance). I suspect that it will be cheaper and more efficient to build 3 PCs with 4 cards each rather than 6 with 2, 12 with 1, etc. I would like to build the first machine ASAP. I am looking for suggestions, and comments regarding a rough draft of a machine. I prefer the nVidia cards because I have already written all the code with CUDA.
CUDA programming, optics calculations
$3,000 for one machine, plus shipping and tax
3) Where do you live?
New York City
CPU, RAM, case, mobo, processor, GPUs, PSU, hard drive, network card
none
6) Will you be overclocking?
no
irrelevant (can use terminal only!)
July - August 2011
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I would like to consider building 1 PC with 4 GPUs (GTX 570). As I understand it, this requires 4 properly spaced PCI-e 2.0 x16 slots, and performance will benefit from a mobo which supports 4 cards at x16 bandwidth. I was considering the ASUS P6T7 but it is very hard for me to determine which mobos ACTUALLY support 4 x16 cards simultaneously. I'm not sure how bad the performance would decline if some cards run at x8, e.g.
I strongly prefer to use Linux, otherwise I can obtain whatever OS license is best.
Here is my draft; please point out all mistakes I have made in choosing these components. I am especially concerned about how the mobo affects performance:
mobo: ASUS P6T7
processor: Intel i7-960
case: Lian Li Lancool PC-K58
PSU: COOLER MASTER Silent Pro Gold Series RSC00-80GAD3-US 1200W (has 8 6 pin connectors for GPUs)
GPUs: 4 nVidia GTX 570s
RAM, hard drive: not too important
OS: OpenSUSE or Ubuntu, latest versions
New York City
none
no
July - August 2011
mobo: ASUS P6T7
