So client of mine has a old custom machine that needs to be upgraded. We are looking to do a i7, 16GB or more, 1GB VideoCard, 256GB SSD with 2-3TB data drive. Client does photoshop and other photo maninipuation. Case needs to have multiple front USB Ports, USB 3.0 and 2.0. Or I can try to do a high end Optiplex and add the necessary gear
- Client runs Photoshop, and standard computer use - Web, Email, Word
- Under $2000. I need to build the machine for client. Normally everything from NewEgg
- US, New York. Generally order from NewEgg
- Everythign but a monitor: Case, Power, CPU, Memory, Hard Drive, Videocard, Operating System, DVD, etc
- Not re-using
6) Will you be overclocking?
- No
- Ultrasharp 24" 2560x1200 (I believe)
- Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
- Client needs lot of USB Ports, Lots on Back and Lots of Front. Need Case that has more than 2 Front USB. USB 3.0 would be good
- Nope
- Not re-using
- No
- Now
- Nope
