It’s been a while since my last build so I have been out of the loop. I need help with this build for my brother.
gaming mostly/web/school work
$400 to $600
3) Where do you live?
Louisiana
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, RAM, case, mobo, os
Reusing Harddrives,ODD and video card (I think it is a GTS 250…I will check)
6) Will you be overclocking?
no
22"
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
like the option of duel video card but not a necessity.
10) Do you already have a legit and reusable/transferable OS key/license?
No, will buy windows 7
Here is the build he put together… I looked it over and it looks OK but want some advise from the best
AMD Phenom II X4 945 $150
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103675
GIGABYTE GA-MA785GMT-UD2H AM3 AMD 785G $90
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128397
G.SKILL 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 $65
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231134
Microsoft Windows 7 Home Premium $104
http://www.newegg.com/Product/Produ...116754&cm_re=windows_7-_-32-116-754-_-Product
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel $90
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
Antec TruePower New TP-750 750W Continuous Power ATX12V V2.3 $109
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371025
Total = $608
Open to any and all suggestions…
$400 to $600
Louisiana
no
22"
Now
Total = $608
