Build compatibility check/comments.
JACK0
Hey, Take a look at my build and see what you think.
Bit of everything
1050 Euro
3) Where do you live?
England
Everything apart from monitor, windows software and keyboard/mous
6) Will you be overclocking?
Probably
One 27 inch, one 21 inch
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Yes, 64bit windows 7
Here is the build I have in mind,
Intel Core i5-2500K Box, LGA1155 €173.55
ASRock P67 Extreme4 (B3), Sockel 1155, ATX €130.55
Sapphire HD 6950 Dirt2, 2GB GDDR5 PCI-Express €215
Crossair 750HX 750 watt €115http://www1.hardwareversand.de/articledetail.jsp?aid=42451&agid=1630
FRACTAL DESIGN Gehäuse DEFINE R3 Black Pearl €89.75
8GB-Kit G.Skill RipJaws-X PC3-10667U CL9 €54.98
Samsung SpinPoint F3 1000GB, SATA II (HD103SJ) €44.09
Samsung SH-222AB bare schwarz SATA €17.71
Scythe Mugen 2 Rev. B, CPU-Kühler, für alle Sockel geeignet €33.99
http://www1.hardwareversand.de/articledetail.jsp?aid=46113&agid=1145hCrucial M4 128GB SSD 6,4cm (2,5") €179
TOTAL €1052
I would aim for a video card from Asus, Gigabyte, MSI, or XFX due to their longer warranty and better customer support.
The two year warranty on that mobo is a deal killer for me personally but if you're fine with that two year warranty, go for it. Otherwise, go for an Asus or MSI mobo.
