Hello, I'm a frequent lurker and occasional poster who has a few questions for those more knowledgeable them I am. Originally I asked in the video card forum about a potential upgrade to my current system but recent events have caused me to reconsider if a full on rebuild may not be a better choice in the long run. See my current board is going on about five years old at this point and for the first few years of its life was exposed to some intermittent heavy dust/tobacco smoke contamination. I did my best to keep it clean there's only so much to be done under those sorts of conditions. As such I am starting to wonder on how much more life may be left in her.
Anyway I have considered doing a rebuild before for the last year or two but kept putting it off as there was always something 'more important' to spend the money on even if given the current U.S. economy it was just tucking it away for a rainy day. While that has come in handy before at this point I'm frankly tired of always saying 'maybe later' whenever I do have a chance. Its the adult thing to do but as long as its not irresponsible whats the point of living if you don't let yourself have a little fun every once in awhile?
Hence why I'm posting here asking what the good people of HardOCP have to say in the matter. Please note that the components I plan to reuse are only a possibility and I am open to altering that list if need be.
Primarily gaming with an emphasis on good looking graphics and reasonable FPS. Also its likely I will have this build, excluding minor upgrades, for 3-5 years. I do NOT plan on engaging in any sort of bitcoin or altcoin mining.
~$1,000 USD maximum with some flexibility for reasonable shipping.
Superior, WI, USA.
Motherboard, CPU, GPU, Case. Potentially display and additional RAM as well.
HDD:
-WD Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5"
PSU
-Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2
RAM
-(2x)G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
6) Will you be overclocking?
I am open to moderate overclocking (4-4.5Ghz on the CPU for example) but nothing to the point water cooling is required.
Current
-20" Acer 203W@1600x1050 720p HD
Planned
-20" to 24" 1920x1080 1080p HD within a year or so of the rebuild. Sooner if the other components plus it all come under budget. Really don't have room nor a desire to go any larger at this time.
Building sometime in the next two months depending on finances with a strong possibility of it being before the end of the month. At worst will have to wait after tax returns though I have nothing against sitting on a component for a month to finish assembly if the deal is hot enough. (Sucks having extra pulled out of my check but knowing I'll have money coming back at the end of the year makes up for it.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
-Some overclocking support as I am open to doing as such.
-Ethernet port due to having cable internet
-Looking primarily for durability over cutting edge performance as it'll likely be a few more years until my next full build as mentioned above.
-Otherwise no real preference on the bells and whistles included.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Win 7 Home Premium x64, OEM builders license
Here is what I'm considering so far:
Case
-NZXT Phantom 630 Full Tower
CPU (I like AMD but Intel appears to have soundly trounced them in the performance department for the time being.)
-i5-3570K Quad Core
OR
-i7-3770K Quad Core
Motherboard
-ASUS-P8Z77-V-PRO
-A Sabertooth would also be tempting considering the interest in moderate OC and the apparent bulletproof construction but outside of a hot deal seems far outside of my price range.
GPU
-Undecided but some flavor of Nvidia
Superior, WI, USA.
HDD:
PSU
RAM
Current
Planned
Case
-i5-3570K Quad Core
OR
-i7-3770K Quad Core
Motherboard
-ASUS-P8Z77-V-PRO
GPU
