Build Advice
kledar586
First of all, this build is my lil 17 year old cousin's first build. He claims he wont be doing much gaming, I'm not so sure. He seems anxious to get it done asap, not sure why, he's going to college next year. I'm just posting this for him.
I will be using my PC mainly for everyday use as well as some gaming. I will not be doing anything intensive on my computer.
My budget is $900 not including shipping or tax.
Sugar Land, TX, USA. (near Houston)
a. CPU
http://www.microcenter.com/single_product_results.phtml?product_id=0354589
b. RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
c. GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150521
d. Optical Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
e. Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112239
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
f. Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148725
g. Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138319
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130583
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131706
h. Monitor (bought) http://www.newegg.com/Product/Product.aspx?Item=N82E16824176198
i. PSU (bought) http://www.newegg.com/Product/Product.aspx?Item=N82E16817371031
I have already bought a monitor for $120 and a power supply for $35 which is to be included in the budget. The power supply unit is 620 Watts, 80+ Silver, ANTEC. The monitor is HP 2311x where the optimum resolution is 1920x1080. I already have a mouse and keyboard.
6) Will you be overclocking?
No
1920X1080. 23” HP2311x Monitor.
I want to build/buy the PC as soon as possible, but preferably finished by December 15th.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I am not entirely sure about what features I will need in my motherboard, but I would like USB 3.0 and SATA 6 Gb/s.
No, but I will be getting a Windows 7 64-bit OS that will not be included in the budget.
my comment to him was, as he claims he's not gonna do much gaming, does he even need the 6850, there are cheaper options
RAM and HDD is OOS. Don't go with that HD 6850 as it's now overpriced due to shipping costs. I'd recommend the HD 6870 as well. I'd recommend the Lian Li case. Of the mobos you listed, I'd go with the MSI. CPU and DVD are solid choices.
