Build Advice
ritch1
been a while since i have built a system, just wanted to confirm that I'm on the right track, with the main components anyway. this is what I'm looking at: -
Processor: - Intel Quad Q9550
Memory: - Corsair 4GB DD2 XMS2 Dominator / PC2 - 8500
Motherboard: - Asus P5Q-E
Graphics Card: -Geforce GTX280 (just the one!)
Operating system: - probably stick with XP for now
Thats based on a little research so if there anything wrong with that I'd appreciate a pointer. Basically hoping a system like that will last a couple of years?
Thanks
You getting a good PSU? I would go with a ATI HD4870 instead of that GTX280 but thats up to you. That RAM is over priced usually, unless you have found some super deal on the corsair dominator RAM you could save some big $$ and you will not notice the diff.
Go here -> http://www.newegg.com/Product/Product.aspx?Item=N82E16820227364 <- there is a nice combo deal on the Q9550 you rlooking to get with that RAM
Go Here -> http://www.newegg.com/Product/Product.aspx?Item=N82E16814102797 <-amazing card low price best price/performance
Here is what i build if I was you:
Q9550 w/ ASUS P5Q Pro mother board combo from newegg - $405 + Shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115041
Solid BFG 650w PSU - $50 + Shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702003
4GB Good low latency G.Skill RAM its only PC6400 but I promise you that makes no difference with the Q9550 chip - $65
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231209
ATI HD4870 Vid card - $235 w/ $20 MIR (it out performs Nvidia)
This is a great machine with a good price/performance ratio - less then $775 now you still gotta pick your drives and case but thats all preference
yep i'll get a pretty decent PSU, still not sure about graphics card, looking for best performance there and the GTX280 seems to be the buzz word but need to research that a bit more. thanks a lot for the help, has cut my costs down already, I'll go for the cheaper memory. I'm not really onto overclocking, just want a decent system that will last a while
Please answer these questions so that we can help you even better:
If you're gonna ask us to build/list a PC for you or seek advice about a build, please answer all of the following questions:
3) Where do you live?
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
6) Will you be overclocking?
7) What size monitor do you have or plan to have?
By answering these questions you help us help you build a better quality/preforming/cheaper PC.
ok no problem
Gaming, web browsing
Around £900 at the MOST
UK
CPU, RAM, Processor, Motherboard, graphics card, PSU, SATA System hard drive (around 150GB), decent processor cooling fan, other cllong fans, RAM cooling
The case is about the only main component I am planning to keep (antec gaming case)
Maybe slightly if possible but not a priority
Dell 24"
Within the next month or so
Thanks for the help
Since never. I have no idea why anyone would recommend a 4870 over a GTX280 as the 280 is significantly faster.
Never indeed. However, it actually is a good recommendation when its for a 22" monitor and/or if the buyer can't afford a 280. ;) But alas, the OP has a 24"... so he'd be better served by the GTX280 or an HD4870X2, IMO. Doh... but his budget is 900. :(
900 pounds, not dollars. Big difference there.
Yah, and aren't things typically more expensive in the UK? Lets see... a GTX280 is £579.28 @ scan, and an HD4870X2 is around £378.22 @ scan. Those are both huge chunks of a £900 budget, especially since he needs a whole build. Maybe they're cheaper at overclockers.co.uk, but I'm too lazy to look -- uk sites load slow for me here at work, lol. Anyhow, of course it can be done, but my point was that the highest end cards may not be within his budget.
That's the super-overclocked watercooled version. A standard GTX280 is as little as £292.90 including VAT at Scan.
Here's a decent build I just threw together:
CPU: C2Q Q9550 - £240.75
Mobo: Gigabyte GA-EP45-UD3R - £100.23 or ASUS P5Q Pro - £101.46
RAM: 2x2GB Corsair XMS2 PC2-6400 CL5 - £40.70
GPU: Leadtek GTX280 - £292.90
HD: Samsung Spinpoint F1 640GB - £45.70
PSU: Corsair VX550 - £58.22
Heatsink: Akasa AK-965BL - £14.09
Total: £792.59 with the Gigabyte board or £793.82 with the ASUS (all prices including VAT).
That leaves over £100 in the budget to add fans, upgrade one or more of the components, or to just keep in your wallet ;).
That's the super-overclocked watercooled version. A standard GTX280 is as little as £292.90 including VAT at Scan. ...
Oh ok, lol. I would've followed through more with where I was going with that (if the cards fit into his budget for a whole build), but each search took over 2 minutes each, and sometimes wouldn't even load for me. Yes, I'm lazy and impatient, lol. It makes me want to put in a req for a faster connection, lol, but I have no justification. :( Nice build, btw.
+1 to the above build.
thanks for the help, really appreciate it. looks like i can easily afford the build I'm looking for, the killer seems to be the top end graphics cards. I'd love a water cooled GTX280 but i just cant justify spending nearly £500, crazyness, costs more than all the other componets put together!
Is their a major difference in performance between the cheaper GTX280s to the more expensive ones, just out of interest. there is a pretty good bundle available at overclockers at the moment, a GTX280 clocked at 615mhz with farcry 2 for £328
great build, i especially like the q9550 p5q pro combo..its great, im getting one myself :D
Just built the p5q pro and q9550, and it's awesome. Just gotta go take the tuniq tower off the old e6400 box.
The only differences depend on whether or not the different manufacturers overclock the cards, but any speed that a pre-clocked card would be set at is generally easily achievable with a standard non-overclocked card and a bit of time.
What, on one artificial benchmark? Are you really making a serious point? Look at the actual games or the sum of the benchmarks and see how badly the GTX 280 thrashes the 4870 512.
http://www.tomshardware.com/charts/...8/Sum-of-FPS-Benchmarks-1680x1050-AA,799.html
Both of those links contain numbers that are severely off. If you really want to compare the cards, look at another site that actually does proper testing, unlike THG.
