I need to transfer important data from a couple of ancient servers (dual-Xeons circa 2006) which are in the process of being virtualised for the migration process, because the servers have already been unracked and we can't run them where they are during the migration - which due to the software in use will probably be a long and painful process.
Assuming the VM process is accomplished successfully, I'm going to need a machine which can be run out of the way in a pretty quiet office space crunching away the data migration process. Once it's done, I'm not sure what will be done with it - it'll probably have a life afterwards, but not for anything major.
OS: Possibly WS2012 temporarily depending on whether we can get away with client Hyper V or nor. Then Windows 8.1 or 9 depending on timing
Requirements:
Power - at least the equivalent of two Xeon 5160's, but doesn't need to be massively over. Needs to host two virtual machines running Windows Server 2003 R2 on top of the host OS( I probably won't be doing it the bare hypervisor way). Max RAM - 16Gb really. The 2003 machines were running with 4Gb RAM so not a huge memory requirement. I'm thinking something along the lines of an E3-1245v3 or a 4771.
GPU - For the purposes of the migration I'll either use onboard if offerd or stick in whatever low-end slot powered 2D Firepro / Quadro that I can lay my hands on. Would probably be prudent to build for a single mid/upper-mid 2-power-socket GPU if required but nothing beyond that.
Storage - Each server needs about 1Tb storage wise. Data redundancy is not really needed - the data'll be written out to external (redundant) storage. Wringing fast transfer for transactional operations (SQL Server and similar type stuff) from the VM's at low cost would be advantageous here.
Priorities: Adequate power to run the migration, silent for quiet office.
My go-to would be:
Define R
Some Asus mobo... Z97-K?
Macho cooler, looks like enough clearance
The abovementioned CPU's
16Gb LP (if required) Corsair RAM
Seasonic X650
2x 1tb or 2Tb drives in RAID0 (I'm feeling lucky)
A 128 or 256Gb SSD - probably an 850 Pro for the host OS
Pretty predictable, right? Anyone have any better ideas?
Requirements:
My go-to would be:
Define R
Seasonic X650
