masteraleph
- Jun 22, 2005
If you're gonna ask us to build/list a PC for you or seek advice about a build, please answer all of the following questions:
Web browsing, typing, and some gaming. No FPSs; most demanding thing will probably be DA3 when it comes out.
1600-$2000
New York, NY. There's a Microcenter about a 15 minute drive away. No Frys around here.
Case, Motherboard, GPU, Processor, Memory, Monitor, Storage (27" 1440p non-Korean preferred), Mouse, Wifi (5 Ghz capability preferred, could be integrated). Would prefer 500GB SSD (1TB seems just too expensive right now, as much as I might want it). Mouse would be replacing a Logitech Revolution MX which has mostly given up charging, so something in that vein would be great. No non-stock CPU cooler required, as I'm not planning on doing any overclocking, unless there's some reason to go elsewhere from the stock Intel cooler.
I'm debating between mATX and mini-ITX. Looking at what's out there, I really like the smallness of the SG10. The SG05 looks incredible in size, but I'm not sure whether I want to go that small or whether it's worth going mini-ITX just for that. Not planning on doing much/any overclocking myself.
If I go with either of these options, I imagine I'd also need an external CD/DVD drive, unless folks think there's a slot-loader worth it on the SG10.
Keyboard (MS Natural 4000). Would love to try an ergonomic mechanical keyboard, but they all seem to be $200+ and I don't know that I can justify the price. Speakers are being done through a Denon receiver and Bookshelf speakers/headphones.
6) Will you be overclocking?
No
As noted, would like a new one- upgrading from a Dell 2407.
Either very soon or mid-October (out of town Oct 7-19).
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
If it's mini-ITX, wifi. Otherwise, nothing in particular, other than some sort of digital output for the receiver.
Legit release copy of Windows 7 (bought years ago through a student purchase program, never used.
Many thanks!
1600-$2000
No
Many thanks!
